03-17-2009, 12:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Seraat-e-Mustaqeem Age: 38
Member: 228476 Status: Offline Sonork: 100.1575078 Thanks Meter: 114 | 1209 Test Mode but when do switch it OFF and power it ON again it shows test mode. after removing the battery for some time and insert the battery again and press its power button it become ON and do power it OFF and power it ON again, it shows Test Mode. I have changed it Flex and also change it BSI resistance but still giving the problem. any friend have its solution? Thanx in Advance. |
The Following 3 Users Say Thank You to Adil Mobiles For This Useful Post: |
03-22-2009, 06:37 | #6 (permalink) |
Member: 228476 Status: Offline Sonork: 100.1575078 Thanks Meter: 114 | Dear i have done all these solutions but still giving the problem any other friend have any other solution? Thanx in Advance. |
The Following User Says Thank You to Adil Mobiles For This Useful Post: |
05-07-2009, 12:25 | #11 (permalink) |
No Life Poster Join Date: Aug 2007 Location: india
Member: 573120 Status: Offline Thanks Meter: 145 | 1200 , 1208 , 1209 test mode for test mode of 1200 ,1208 ,1209 first of all its charging jak problem change charging jak ur problem ll 99% solve . if not then change 4 leg resistence near uem . |
The Following 3 Users Say Thank You to jagdish puri For This Useful Post: |
1200-1208-1209 local/test mode final solution {UPDATED} | izhanji | Nokia Hardware & Hardware Repair | 34 | 08-15-2016 13:30 |
solutions can't local mode,test mode,normal mode after reflash in here | uwenk98 | Nokia Hardware & Hardware Repair | 30 | 07-27-2013 11:27 |
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested | /\/\A/\/| | Nokia Hardware & Hardware Repair | 14 | 07-11-2011 05:49 |
1209 Local Mode Test Mode Salotion | atulharnal | Nokia Hardware & Hardware Repair | 5 | 04-23-2011 15:01 |
Test mode, Local mode Normal mode | royke | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-13-2002 11:33 |
