..::1280 dead any solution::.. i got this phone in dead condition not a dropped phone not water damage set suddenly dead i flash with latest version but still no power also change lcd VBATT OFF... VBATT ON Setting VBATT Done!... Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.200 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0E71 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2020800 bytes Data Checksum: 0C57 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.20aa PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0039D37E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1627008 bytes Data Checksum: E884 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai06.20aa CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F0793E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 358720 bytes Data Checksum: B1D0 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:20 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... ERROR : PHONE READ INFO FAILED i try these ways but still same try flashing with atf and mxkey flashing complete but ui failed when connect to power supply and press power key set take power and needle continuously shaking but set not power on |
first check display.....very few chances of display problem in ur case acc to log... but first check it .... if not solve then rehot cpu ... post result.... |
already reball cpu and flash ic......................... |
just cheak battary connector middle point.that means bsi |
bsi print ok..................... |
change display............... |
remove charging connector and flash again tested solution |
change 26mhz will be ok post result back |
cheak display then cheak bsi line |
