..::1280 no lcd and keypad light::.. 1280 no lcd and keypad light action taken: change lcd change diode change led change coil change transister chk tracks but still same? any solution mates? |
dear ur solution is here http://forum.gsmhosting.com/vbb/f148...100-a-1082194/ |
dear read the model carefully |
brother nokia 1280 and 1616 same? i think same but you also check if same then try this [IMG]http://1.bp.********.com/_haRAPmO1Seg/TGrH7Q9388I/AAAAAAAAAac/4_l4kgQgBw4/s320/Nokia+1616+and+nokia+1800+LCD+display+backlight+LE D+solution.jpg[/IMG] |
its different from 1616............. |
i already rehot main ic but still same |
any solution...................................? |
check your way ...bro |
i try these ways but still same try flashing with atf and mxkey flashing complete but ui failed when connect to power supply and press power key set take power and needle continuously shaking but set not power on |
Thank you so much its working100000000000000% |
All Track Ok But No Luck. |
Same Problem With Me ............................ |
Good Sharing and good soloution |
brothers plz help me nokia 1280 with out lcd light showing display and with light no disply? |
