Old 08-28-2007, 15:26   #1 (permalink)
Member: 434317
Thanks Meter: 15
1600&2310 +ve and-ve have shorts
Hi friens, Nokia 1600&2310 Handset is dead.+ve &-ve have shorts.
even if the PFO is removed.still it shorts.whats the problem?
Please help.
Old 08-28-2007, 15:36   #2 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
check led ic its under keypad,then check ringtone ic(near Uem)
Old 08-28-2007, 20:28   #3 (permalink)
Member: 560008
if you have a battry meter ,connet corsponting + ve & - ve terminals & apply 1volt it gives minimal heat board sections ( UEM IC & LED IC & RINGER IC & network PF ) and find out the area & do remedy.
Old 08-29-2007, 04:53   #4 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
power ic /audio ic mostly short in this case but dear some time charging ic alittle 4 leg causses this problem check it out and post here result
Old 08-29-2007, 16:42   #5 (permalink)
Member: 236236
Thanks Meter: 16
Check The Carge Point
Old 08-29-2007, 20:06   #6 (permalink)
Member: 434317
Thanks Meter: 15
friens,thanks for ur sharing. Ill do that.
Old 08-30-2007, 05:25   #7 (permalink)
Member: 350571
Thanks Meter: 920
Please help.
Remove PA ic
then check and reply
All VE-Pro and VE-King Software Update here sagtel VE-KING 1 04-16-2012 06:49
i have infinity box and ve-pro box but dont have pin finder. sahil00150 Infinity-Box 2 06-20-2008 21:01
Difference between ve-pro and ve-king usman0000 VE-PRO BOX 3 06-13-2008 07:31
VE-King , VE-Pro Box official Distributors And Resellers List Update ! saigonmobile VE-KING 0 06-02-2008 06:04
VE-King , VE-Pro Box official Distributors And Resellers List Update ! saigonmobile VE-PRO BOX 0 06-01-2008 10:16
Page generated in 0.16253 seconds with 9 queries
