09-13-2009, 08:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india
Member: 729723 Status: Offline Thanks Meter: 211 | 1600 After flash processing... Waiting for phone to boot... Failed! Aborting! Detected PKEY: 9000FA1B Card life counter: 54.20% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02mg CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02mg ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Hindi,Marathi Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020 Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.02 MSID: 848D45657F81BF420EC4D8F094 MSID decoded: 3E4EBAE9001238A5A9000000 FAID: D50FB0853D9C41A3F4E2746C Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 28 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02mg Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.02 MSID: 848D45657F81BF420EC4D8F094 MSID decoded: 3E4EBAE9001238A5A9000000 FAID: D50FB0853D9C41A3F4E2746C Operation took 0 minutes 15 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011D0000 - 011DFFFF... Erasing area: 011E0000 - 0137FFFF... Operation took 0 minutes 12 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02mg Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2A0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: c6 Loader is ready... P-key nokia module version 01.02 MSID: 843951DDE2909E81B16B9B2AED MSID decoded: 3E4EBAE9001238A5A8000000 FAID: 279C10DEB55EB116872A7D05 Operation took 0 minutes 11 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013BFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 2 minutes 21 seconds... |
09-13-2009, 08:10 | #2 (permalink) |
Member: 729723 Status: Offline Thanks Meter: 211 | in hwk 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.0.9.0] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 848D45657F81BF420EC4D8F094 Decoded MSID: 3E4EBAE9-001238A5-A9000000 Encoded FAID: D50FB085-3D9C41A3-F4E2746C IMAGE: rh64_07.020 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:30 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:11 IMAGE: rh640_nai7.02mg Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
09-13-2009, 08:52 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,682 | write full flash........................ |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
09-13-2009, 19:29 | #8 (permalink) | |
Junior Member Join Date: May 2008
Member: 771510 Status: Offline Thanks Meter: 7 | Quote:
re boll upp ic then complete ic | |
The Following 3 Users Say Thank You to mass_zoro For This Useful Post: |
09-13-2009, 19:47 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Try to erase and then flash with 4.04 version and post the result... |
The Following User Says Thank You to ..::My3gtech::.. For This Useful Post: |
09-27-2010, 07:24 | #10 (permalink) |
Junior Member Join Date: May 2008 Location: chandigarh....batala
Member: 775389 Status: Offline Sonork: deepak Thanks Meter: 2 | 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.0] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 846B62C3F14075466AA63D1AA9 Decoded MSID: 3E4EBAE9-00942569-A9000000 Encoded FAID: D77EFA82-33755FB5-A5676FE6 IMAGE: rh64_07.020 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:37 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:15 IMAGE: rh640_nai7.02mg Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Last edited by premdhillon; 09-27-2010 at 07:26. Reason: plz help me?????????????? |
09-27-2010, 07:44 | #11 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
bro with hwk manual flash 1st mcu 2cd ppm now see info mabe your imei crupted | |
11-13-2010, 13:49 | #12 (permalink) | |
No Life Poster Join Date: May 2008 Location: india / Tamil nadu
Member: 773423 Status: Offline Thanks Meter: 82 | Quote:
Alot of Nokia BB5 Flashing Problem??? Waiting for phone to boot... | nofear99 | Nokia Base Band 5 ( BB-5 ) | 7 | 04-23-2010 14:23 |
Nokia Experts plezzz help..... Waiting for phone to boot... | nofear99 | Nokia Base Band 5 ( BB-5 ) | 0 | 02-14-2010 16:53 |
After flash processing... Waiting for phone to boot... Reading... Failed! Aborting!.. | rohinikumar | Nokia Hardware & Hardware Repair | 6 | 12-15-2009 09:01 |
