Old 03-06-2009, 12:38   #1 (permalink)
Member: 979869
Thanks Meter: 17
1600 contact service
1600 contact service change sim ic this problem not solved.........any soulations.
Old 03-06-2009, 13:20   #2 (permalink)
Member: 758126
Thanks Meter: 27
Try to flash it.....
Old 03-06-2009, 13:24   #3 (permalink)
pathfinder333's Avatar
Member: 954575
Thanks Meter: 244
flash it in high version write pm unlock then full fact.....
Old 03-06-2009, 13:25   #4 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
try write good pm
if no luck
erase flash
flash higher version
write pm unlock
The Following User Says Thank You to venuno For This Useful Post:
Old 03-06-2009, 13:38   #5 (permalink)
Crazy Poster
Member: 984054
Sonork: 12345
Thanks Meter: 9
if u have ub box first erase with given erase file and flash with 7.02 write given pm file it may help
jai sri ganesh
Old 03-06-2009, 13:43   #6 (permalink)
Member: 486315
Thanks Meter: 2
First Use this Address when erasing
Start Address: 013F0000
End Address: 013FFFFF
2. Then, Flash to high firmware
3. Write PM
4. UI Setting
5. Unlock
either you damages the UPP IC
Old 03-06-2009, 14:09   #7 (permalink)
NAVEED74's Avatar
Member: 188574
Sonork: 100.1590742
Thanks Meter: 751
brother romve front side keypad sticker. and give heat on uem from front side. not from top of uem.
take care while giving heat. and i am sure your problem will be solved..
Naveed Yousaf
1600 Contact Service vbfather Nokia Hardware & Hardware Repair 92 07-22-2012 18:13
Fix Our 1600 Contact Service hamzehest Nokia Hardware & Hardware Repair 52 10-01-2007 16:36
1600 ConTact Service PIMP123 Nokia Digital Core Technology 4 ( DCT-4 ) 4 05-11-2006 19:06
1600 Contact Service H_C_K Nokia Digital Core Technology 4 ( DCT-4 ) 16 04-10-2006 03:37
Page generated in 0.18733 seconds with 10 queries
