View Poll Results: Contact Service -- Harware or Software. | |||
Hardware | 1,316 | 59.82% | |
Software | 271 | 12.32% | |
Both | 613 | 27.86% | |
Voters: 2200. You may not vote on this poll |
03-28-2008, 08:47 | #61 (permalink) |
Banned Join Date: Feb 2007
Member: 445578 Status: Offline Thanks Meter: 440 | |
The Following User Says Thank You to sumon.bd For This Useful Post: |
03-29-2008, 11:12 | #63 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Chennai, Tamilnadu, India
Member: 205776 Status: Offline Thanks Meter: 53 | when u remove the ic u should be very careful. i think u have damaged uem , because when u remove the insert sim ic ur uem ic will get damaged... and u will get contact service... only one solution for contact service is that if it is water damaged clean the pcb well in white petrol or ip.. there is no solution for contact service right now.. |
04-01-2008, 15:09 | #64 (permalink) |
No Life Poster Join Date: Feb 2007 Age: 41
Member: 449518 Status: Offline Thanks Meter: 585 | 100% hardware bro.try da solution above n if nt bad luck.pointless spending time for a phone like 1600 for more than that.try to replace a pcb try this |
The Following User Says Thank You to sujan1050 For This Useful Post: |
04-06-2008, 11:33 | #68 (permalink) |
Junior Member Join Date: Jan 2008
Member: 682732 Status: Offline Thanks Meter: 4 | sir i have nokia 6085 which is water damage.i clean pcb very well now set on but when i start camera set is auto restart. i flash with new flash file but no result it's strip&camera section was ok i check with other 6085 set plssssssssss give me solution.... |
04-06-2008, 12:25 | #70 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Hello friends I changed hot air nozzles shape from round to square and it perfectly covers the ic.I chenged many KP ic and sim IC without damaging UEM or Sim tray.Diffrent size nozzles should be used for KP ic and SIM ic. |
The Following User Says Thank You to baldev For This Useful Post: |
04-06-2008, 15:35 | #72 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | Cotact service Solution All My Friends I Face This problem. A long Time Ago. Then i make This Solution. This Problem Came Over Temperature. I Remove Sim Ic With Smd rework station This Angle. Please Give Your Comets. |
The Following 2 Users Say Thank You to papoo For This Useful Post: |
1600 contact service and invalid sim | HUM | Nokia Hardware & Hardware Repair | 12 | 12-11-2010 07:04 |
1110 contact service by changing sim ic | Options Media | Nokia Hardware & Hardware Repair | 2 | 07-29-2009 15:25 |
1110 contact service after chang sim ic | Elias Khan | Nokia Hardware & Hardware Repair | 1 | 06-13-2009 13:57 |
1112 & 1600 contact service/sim not valid | .:SARCAR:. | Nokia Hardware & Hardware Repair | 2 | 06-16-2008 07:08 |
