10-02-2006, 11:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | 1600 dead-Bad Resp UPP, 03 00 00 72 I HAVE A 1600 DEAD. WHEN CLICK IN CHECK OPTION IN UFS SHOWS FLLOWING ERROR MESSAGES 1st Boot Err: Bad Resp UPP, 03 00 00 72 1st Boot Err: Bad Resp DCT3 Rebooting Mobile I HAVE HEARD THAT BAD RESPONSE UPP ,O3 IS DUE TO UPP PROBLEM. ANY FRIENDS IN FORUM KNOW HOW TO IDENTIFY UPP,UEM,FLASH ,RAM,FAULTS FROM UFS ERROR LOGS IT WILL HELPFUL TO AVOID TRIAL AND ERROR METHODS THANK U Last edited by zonetrichur; 10-02-2006 at 12:01. |
10-14-2006, 12:21 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Such An Error In Most Cases Is As A Result Of Poor Connection Between Cable And Phone And Or Cable And Box Especially If The Cable Clip Is Damaged. Also If The Battery Connector Of The Phone Is Bad You Can Get The Phone Flashed Unless You Change In A New One. |
10-14-2006, 12:28 | #4 (permalink) |
Member: 319112 Status: Offline Thanks Meter: 164 | Check The Battery Connector. If It Is Deformed, Then You Have To Change In A New One. Also If The Cable Clip Is Damaged You Have To Fasten It To The Box With Help Of Something. And.. Most Times, You May Have To Hold The Cable To Phone With Your Hand Or With The Help Of Rubber Band As The Cable May Not Fit In At Times. |
The Following User Says Thank You to ABUU YUUNUS For This Useful Post: |
08-26-2009, 12:17 | #7 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | 1) change cable 2) clean data point 3) clean bettery Terminal or change 4) flash ic problem.......................... with best wishes... |
1st boot err : Bad resp upp , 03 00 00 72 | mosc2 | Twisterflasher | 16 | 07-19-2014 13:53 |
1st Boot Err: Bad Resp UPP, 03 00 00 72 | XARiUS | UFS2 + UFS3-Tornadoflasher | 5 | 10-05-2011 15:12 |
1st Boot Err: Bad Resp UPP, 03 00 00 72 (NOKIA 6230.) | davoldv | UFS2 + UFS3-Tornadoflasher | 6 | 08-15-2010 16:53 |
1st Boot Err: Bad Resp UPP, 02 FF FF 72 | ficho | UFS2 + UFS3-Tornadoflasher | 14 | 01-10-2010 09:28 |
7250i - Bad Resp UPP, 02 FF FF 72 problem | northernbloke | UFS2 + UFS3-Tornadoflasher | 7 | 11-17-2004 00:15 |
