Old 04-05-2010, 14:37   #1 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
1600 dead very strange problem
I have many of nokia 1600 dead ,i flashed it and takes full flash ok,full ui satting ok,it is changing mode ok (local mode,test mode,normal mode).but nothing is showing in display.
And phone is not going turn on with battry,can anyone give me feed back.
Old 04-05-2010, 14:41   #2 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
To lead then attempt times after Flash directly UNLOCK through!
Old 04-05-2010, 14:46   #3 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
remove the double resistence,of local mode,,,,,also check battery terminal, - 1,,,,,,if not succes,,,check upp,,and also full flash,and then unlock,,plz post result
Old 04-05-2010, 15:04   #4 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
'CHECK"
here is logo with jaf
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
INFO----
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-64
(c) NMP
HW version: 0502
PCI version:
UEM version: 1314
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-64
(c) NMP
MG
ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nmg
Production serial number: ICA627402
Product code: 0525146
Module code: 0202591
Basic production code: 0520754
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 35***********
IMEI spare to net: 3A 25 62 00 21 02 18 00
IMEI SV to net: 33 25 62 00 21 02 18 40 F5
Master Code: 3425162315
Phone type: RH-64, Software version: 7.02, Language Pack: MG
User code: ÿ#
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0525146
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02mg
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02mg
Languages in ppm: English,Hindi,Marathi
Done!
Old 04-05-2010, 15:08   #5 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
FOR UNLOCKING-----
Unlocking...
IMEI: 3522***********
ASIC: 2
SW version: 7.02
Failed! Aborting!
Failed! Aborting!
Nokia 1600 very strange problem celluniversal Nokia Hardware & Hardware Repair 6 09-30-2007 08:11
UFS3 + HWK very very strange problem ???????????? makroud UFS2 + UFS3-Tornadoflasher 2 04-13-2006 10:14
M35 DEAD - Very Strange Problem! johny3310 x1x to x45/x50 11 06-07-2004 01:58
s300m very very very strange problem mp3hot Trident/AGERE Platform 0 02-03-2004 20:29
Very Very Strange Problem On Be4 Pandemonio100 Alcatel & TCL Old Models 1 06-25-2002 20:00
Page generated in 0.16755 seconds with 9 queries
