04-04-2009, 19:12 | #1 (permalink) |
Insane Poster Join Date: Feb 2009
Member: 979869 Status: Offline Thanks Meter: 17 | 1600 different lighting falt 1)light ic 2)coil 3)141 tranistor 4)led 5)display 6)display connector this problem not solved.......... |
The Following User Says Thank You to yakkathali For This Useful Post: |
04-05-2009, 06:10 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | check voltage at coil(L2400) 1.If no voltage make a jumper from Battery terminal if ok Check R2400 Near the LED OR short that 2.test that if LED is turn on while short with a plucker(twiser) from V2401 different legs 3. if ok test with a plucker(twiser) to C2400 to R2400 if ok make jumper to the display connecter Because in 1600 Led is in serial connection please post the result |
04-06-2009, 07:43 | #7 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Pune (Daund) Maharashtra Age: 34
Member: 787710 Status: Offline Sonork: not using Thanks Meter: 771 | [IMG][/IMG] TRY THIS TRICK BRO.... Ur PRObleme IS SOLVE |
The Following User Says Thank You to suraj9860607689 For This Useful Post: |
1600 LCD Lights ok but Keypad lights not working | Adil Mobiles | Nokia Hardware & Hardware Repair | 4 | 01-25-2010 19:19 |
6120c lighting falt | yakkathali | Nokia Hardware & Hardware Repair | 6 | 08-28-2009 22:17 |
solution for 1600 display light | joegel | Nokia Hardware & Hardware Repair | 4 | 10-30-2006 12:46 |
1600 no light | lidar | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 08-21-2006 16:19 |
1600 lcd light problem? | saifmobile | Nokia Hardware & Hardware Repair | 0 | 08-05-2006 22:05 |
