Old 02-20-2008, 20:52   #1 (permalink)
Member: 102582
Thanks Meter: 72
1600 Flashing Error Message..need Help
Hello Mates,
One Nokia 1600 Phone came to me as dead. The phone's PCB is absolutely clean. I didn't put any effort in terms of Cleaning and Heating. Straingtway, I connected with the ORIGINAL UFS-3 SOFTWARE + HWK Chip. I tried to flash the phone with Ver 3.42 & Ver 5.54, but each time giving me the following message :
Nokia 1600 Flashing Error
1st Boot Ok, DCT4, UPP: 2201
Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE
Algorithm: u_amd.fia, Ver: 4.68.0
Algorithm Ok, MSID: 84BDEF8F09455F3FE9CB2E526D
Decoded MSID: 3E4EBAEB-00CCFFA5-A8000000
Encoded FAID: F641C79E-6B9856BD-544387C8
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x013BFFFF Erased, Time: 00:26
Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
Write Error: hDat 14, at: 0x01040000:08
Process Failed, Repowering Mobile
Where is fault and how to solve it?
Advance thanks,
amit123
Old 02-20-2008, 21:09   #2 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
Originally Posted by amit123 View Post
Hello Mates,
Advance thanks,
amit123
dear amit. do the following instuction.
1- erase fls
2- flash ver.5 to ver.6
1000% working
Old 02-21-2008, 12:49   #3 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
If the above solution is not work, change the CPU.
If its not work than change the Flash IC than check.
Old 02-22-2008, 08:51   #4 (permalink)
Member: 262039
Thanks Meter: 7
Try to rehoot flash IC
Old 02-22-2008, 09:11   #5 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
Reball the flash Ic .................
Old 02-22-2008, 10:07   #6 (permalink)
Member: 696372
Thanks Meter: 11
why u should not try jaf
Old 02-22-2008, 10:16   #7 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Just heat the Flash and UPP and flash latest version.
6610i flashing error (log) need help dapinderjit Nokia Hardware & Hardware Repair 1 03-14-2009 21:01
1600 Flashing Error Help Me kmshawon Nokia Hardware & Hardware Repair 15 08-19-2008 13:19
2310 Flashing Error Message..pls. Help amit123 Nokia Hardware & Hardware Repair 6 07-21-2008 09:47
Page generated in 0.16886 seconds with 9 queries
