1600 goes blank after 5 sec hai to all mem 1600 when i switch on the mobile set is ok but after 5 sec screen goes blank and nothing will work i have flashed with jaf and ufs with latest ver also but same problem need urgent helpthe mobile set is ok but after 5 sec screen goes blank i have flashed with latest ver also but same problem :confused: need urgent help |
Pls check if the imei is not like this ?????????????????? |
and checked every thing is ok i got two |
i think it is UPP problem...... |
!!!!!!!!!!!!!!!!!uem faulty |
Try software solution first. Use erase flash, fullflash,write good pm, ui settings. If no luck try to reheat flash ic. pls post result |
i think its uem fault................. |
NOKIA 1600 when i switch on the mobile set is ok but after 5 sec screen goes blank and nothing will work i have flashed with jaf, UB , MX key and ufs with latest ver also but no result....any solution please post........Thanks in advance.......... |
Nokia 1600 go blank after 5 sec. NOKIA 1600 when i switch on the mobile set is ok but after 5 sec screen goes blank and nothing will work i have flashed with jaf, UB , MX key and ufs with latest ver also but no result....any solution please post........Thanks in advance.......... |
..::Brother to reheat is uem so chk it::.. |
1600 blue screen i think upp problem.het upp from other side problm will solve |
