08-02-2008, 11:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 301177 Status: Offline Thanks Meter: 91 | 1600 imi shows ?????????4 |
The Following User Says Thank You to ameho0102 For This Useful Post: |
08-02-2008, 11:31 | #2 (permalink) |
Junior Member Join Date: Jun 2007
Member: 535613 Status: Offline Thanks Meter: 9 | my nokia 1208 flashing after this problem pls..........help Getting MCU ID MCU ID: 0x2292 FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.720 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.72aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai3.72aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_03.720 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07 Flash ID is 0x01000000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: d7 Loader is ready... P-key nokia module version 01.02 MSID: 843ADDD1889846B948CAB98089 MSID decoded: 3E4EBAE900D2CA35A9000000 FAID: B50082BE03CF3C976FF37F90 Operation took 0 minutes 9 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 1 seconds... Writing... Error cmd: 14! Addr: 01000000 |
The Following User Says Thank You to pratap.nakum For This Useful Post: |
08-02-2008, 11:53 | #4 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: EARTH!
Member: 521295 Status: Offline Sonork: 100.1657160 Thanks Meter: 172 | Quote:
if jaf ur problem is solved just writh backuped rpl... | |
1600 nokia shows Stop or not Charging | abidalius007 | Nokia Hardware & Hardware Repair | 12 | 11-15-2012 11:04 |
1600 always show low battery. | tahir-khan | Nokia Hardware & Hardware Repair | 8 | 05-17-2010 04:56 |
3110c imi show 123456....and contecservices help | SRUCHI | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-07-2010 06:21 |
1600 Imie Patching ERROR | asadnow2k | Universalbox | 4 | 08-21-2008 06:42 |
1600 Imie Patched | asadnow2k | Universalbox | 7 | 08-15-2008 11:08 |
