Old 03-01-2011, 09:41   #1 (permalink)
salmaan shaik's Avatar
Member: 1271316
Sonork: 501101
Thanks Meter: 22
1600 inert sim ites urgent
hi forum member & guest i have 1600 i chang sim ic & all jumper but some time ok or some time not please give me right solution thanks in advence
The Following User Says Thank You to salmaan shaik For This Useful Post:
Old 03-01-2011, 09:45   #2 (permalink)
Member: 798847
Thanks Meter: 11
clean or change charge conector
change battery
if have short with sim ways change power ic
The Following 3 Users Say Thank You to mnaouar For This Useful Post:
Old 03-01-2011, 09:48   #3 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
clean your batrry pin & not ok change flash ic
The Following 2 Users Say Thank You to yuresh For This Useful Post:
Old 03-01-2011, 17:51   #4 (permalink)
OTIENOJULIUS's Avatar
Member: 898387
Sonork: 1000.2
Thanks Meter: 103
Originally Posted by aravintharmy View Post
sir try plzzzzzzzzzzzzzzz 100% okkkkkkkkk[IMG]http://3.bp.********.com/_9Z7dTG7H9HQ/TP9N5LH0wYI/AAAAAAAAAhI/TxTjzvTCDM0/s1600/simconnectortosimicwayschecking.jpg[/IMG]
..this will solve your problem
The Following 2 Users Say Thank You to OTIENOJULIUS For This Useful Post:
Old 03-01-2011, 18:20   #5 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
change your battery and see (BL-4C)
The Following 2 Users Say Thank You to mendis For This Useful Post:
Old 03-01-2011, 23:35   #6 (permalink)
Member: 739947
Thanks Meter: 10
remove local mode it work 10000000000000%
The Following User Says Thank You to ehab4224 For This Useful Post:
Old 03-03-2011, 10:42   #7 (permalink)
Member: 583454
Thanks Meter: 80
If Instert sim shows directly it means u need to change sim ic if it shows after few seconds when power on it means it is bsi related problem change local mode component and clean c.c surface
Old 03-03-2011, 12:14   #8 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
Bro pleace check some sim way (NOT GROUND PIN) Short with ground
if short heat UPP little bit
Old 03-03-2011, 16:10   #9 (permalink)
Member: 1525108
1600 inert sim
try this bro. inert sim
Old 03-03-2011, 18:19   #10 (permalink)
Member: 642050
Thanks Meter: 17
change the charging connector
Old 03-04-2011, 07:11   #11 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
Sim VCC way is short?????????????????
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.21502 seconds with 10 queries
