Old 07-12-2010, 09:38   #1 (permalink)
Member: 551619
Thanks Meter: 136
1600 Insert SIM
Friends I got Nokia 1600 with Blue LCD after few Seconds Problem..
Phone was Water Damege..
Blue LCD Problem was Solved by Cleaning & Heating this Area :
but now Phone Shows Insert SIM..
I changed SIM IC
still Same
I tried Jumper Solution Like this :
still Same
So I make Jumper Like this :
Still Same
I Flashed the Phone & write Tested PM
but Still Same..
How to Solve this Problem..???
Please Help me Friends...
The Following User Says Thank You to SkyNet4u For This Useful Post:
Old 07-12-2010, 10:07   #2 (permalink)
Member: 551619
Thanks Meter: 136
Please Help Me Friends...
Old 07-12-2010, 10:39   #3 (permalink)
Sandeepjagdeva's Avatar
Member: 495742
Sonork: N O W H E R E
Thanks Meter: 49
did U check the Registance of ur PCB. is it normal? Have u make jumppers for blue screen? did Sim working before blue scree solution u made?
Old 07-12-2010, 10:58   #4 (permalink)
Member: 551619
Thanks Meter: 136
SIM was Working Correctly before Heating..
I Heat Components near SIM IC for Blue LCD..
Old 07-12-2010, 11:28   #5 (permalink)
Member: 495742
Thanks Meter: 49
Just check the voltage on C2208 capacitor it should be near 3.2v. it is up side of SIM IC. OR As per ur sitution it seems that its a problem of UEM, u can gently heatup the UEM with lots of soldring paste. But be careful coz heating UEM may result in no power on. so be careful and gently heat it.
it will be OK.
Old 07-12-2010, 11:33   #6 (permalink)
Member: 551619
Thanks Meter: 136
it will be OK.
Ok I'll try
& Thanks for Reply..
Old 07-12-2010, 13:28   #7 (permalink)
Member: 1081011
Sonork: 100.1594100
Thanks Meter: 463
Brother Remove r Change 4 Legs Resistor Near UEM ....................
Old 07-12-2010, 15:12   #8 (permalink)
Member: 551619
Thanks Meter: 136
Can you Upload any Pic for this..???
Old 07-12-2010, 15:18   #9 (permalink)
the jinnah's Avatar
Member: 683063
Sonork: 100.1617868
Thanks Meter: 136
check this bro
Test local mode.jpg - 4shared.com - photo sharing - download image
Old 07-12-2010, 15:31   #10 (permalink)
Member: 551619
Thanks Meter: 136
Originally Posted by the jinnah View Post
Thanks Bro but it is Local & Test Mode Solution
I need Insert SIM Silution..
Old 07-12-2010, 15:42   #11 (permalink)
Member: 1342188
Sonork: 100.1607654
Thanks Meter: 129
e 71 network problem
Old 07-12-2010, 18:23   #12 (permalink)
the jinnah's Avatar
Member: 683063
Sonork: 100.1617868
Thanks Meter: 136
bro any time this remove set ok work sim card
Old 07-13-2010, 08:18   #13 (permalink)
Member: 551619
Thanks Meter: 136
Friends by My Mistake This Two Tracks of SIM IC are Damege
I have This Solution but I cant Understand this
I need Help to Solve this..
Old 07-13-2010, 09:51   #14 (permalink)
Member: 551619
Thanks Meter: 136
Old 07-13-2010, 11:45   #15 (permalink)
Member: 1320426
i encounter that kind of problem a month ago. its a cruded charging pin. just try to change the charging pin.
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.24798 seconds with 10 queries
