Old 06-13-2006, 10:31   #1 (permalink)
Member: 70916
Thanks Meter: 56
1600 keypad problem
hai any one can help me
1600 mobile keypad is not working properly ie some keys works and some not works
have any solution or diagram please post
thanxs in advance
Old 06-13-2006, 10:39   #2 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Thanks Meter: 4,002
hi boss!just clean the keypad interface,gud luck
Old 06-13-2006, 13:36   #3 (permalink)
Member: 70916
Thanks Meter: 56
hai nonoy u think i didnt do that thing i have cleaned it will & check the p supply it ok but some krys not working there is a key pad glass ic any alternative circut for bypass
Old 06-17-2006, 00:36   #4 (permalink)
Member: 152104
Thanks Meter: 5
try to get a white eraser service the panel, after that then clean the interface with the eraser and make sure there is no contact of i.c on the panel and ensure that there is no luping on the board.
Old 09-01-2006, 19:20   #5 (permalink)
Member: 123261
plz help me mine is only the center keys 2,5,8,and 8
Old 09-01-2006, 19:36   #6 (permalink)
Member: 330673
Thanks Meter: 6
as I can release estemovil 1600 I have returned box ufs3
Old 09-01-2006, 19:39   #7 (permalink)
Member: 330673
Thanks Meter: 6
pinout of this nokia 1600 urgent nesecito to release it urgent
Old 09-01-2006, 22:03   #8 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
thanxs in advance
here is your fault....... change it or heat this....
Old 09-02-2006, 00:56   #9 (permalink)
Member: 283474
Thanks Meter: 41
pls & pls mate, don't take d risk of heating or replasing it , unless u are ready to buy another one, if u heat too much d legs will bridged and it will result to all d legs malfunctioning, if u try to remove it ,it won't work . Im speaking frm expi. The best solution is to return it to d owner. THANKS
Old 09-02-2006, 06:46   #10 (permalink)
mohamedsafi123's Avatar
Member: 170244
Thanks Meter: 418
mohamedsafi
dear friend]
good service man not return any handset sir pls try glass ic heat or change this is not ok normel heat in cpu fault is solved thenks...........
Old 09-26-2006, 20:50   #11 (permalink)
Member: 23786
Thanks Meter: 15
yes, CPU !!! Good work, rehot and all ok, keypad work perfekt, thanks mohamedsafi123
Old 09-26-2006, 23:33   #12 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
only change key pad IC ur prob will be solve ,thats near sim jecket,tested 100%
Old 01-14-2007, 16:37   #13 (permalink)
Member: 415588
after changing keypad ic the set s dead help please
Old 01-20-2007, 08:52   #14 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
plz change keypad ic maybe yours problem
Old 04-26-2008, 13:39   #15 (permalink)
Member: 759649
thanks and hav ancf day
Nokia 1600 Keypad Problem Amarbir Nokia Hardware & Hardware Repair 18 02-28-2014 07:15
1600 Keypad Problem shok9992000@yah Nokia Hardware & Hardware Repair 3 11-28-2007 16:04
1600 keypad problem.. ..:MumbaiGsm:.. Nokia Hardware & Hardware Repair 8 06-18-2007 05:01
1600 keypad problem help urgent jbbasha Nokia Hardware & Hardware Repair 9 08-25-2006 07:28
1600 keypad problem google_uk Nokia Digital Core Technology 4 ( DCT-4 ) 4 04-11-2006 04:22
Page generated in 0.29480 seconds with 10 queries
