Old 02-04-2006, 13:31   #1 (permalink)
Member: 77549
Sonork: 100.89357
Thanks Meter: 11
6680on/off
i cant findout the on/off switchs track of a 6680. phone does not power on but indicates charging.pls help by giving diagram.phone is water damaged.
Old 02-05-2006, 13:08   #2 (permalink)
naughtycell's Avatar
Member: 214350
Thanks Meter: 17
This is the 6680 power-Sw schematics/layout , check z4401 also , cause I think it may be involved in water effects .
The Following User Says Thank You to naughtycell For This Useful Post:
Old 02-10-2006, 05:37   #3 (permalink)
Member: 77549
Sonork: 100.89357
Thanks Meter: 11
thanks
thank you sir,thanks a lot.
Old 02-18-2006, 21:29   #4 (permalink)
Tanvir's Avatar
Member: 20691
Thanks Meter: 20
@naughtycell
Nice work bro .... but we repaired this ON/OFF track problem long time ago by making jumper on small silver IC at the upper side of keyboard connector Nice solution really ...
Regards,
Tanvir !
Old 02-18-2006, 22:55   #5 (permalink)
Member: 21937
Thanks Meter: 279
Originally Posted by Tanvir
@naughtycell
Regards,
Tanvir !
can you please show solution ? got 6680 water damage right on power switch , all circute with ic was damaged .
phone show charging and power on with jaf , np reading or flashing.
thx
Old 02-19-2006, 00:01   #6 (permalink)
Tanvir's Avatar
Member: 20691
Thanks Meter: 20
check the above pics gaved by @naughtycell...
In 6680 on/off switch track goes on the small glass ic which is on the upper side of Keyboard connector, it's called : Z4401
Regards,
Tanvir !
Old 02-19-2006, 00:41   #7 (permalink)
Member: 21937
Thanks Meter: 279
Regards,
Tanvir !
so you say just remove the glass ic and jumper
IN1--->OUT1
IN2--->OUT2
Old 02-19-2006, 12:02   #8 (permalink)
Member: 21937
Thanks Meter: 279
anyone know value of this resistor ?
and if its any metter to power on ?
Old 02-19-2006, 13:15   #9 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
please, remember to check other componments on phnoe before any thing else.
i wish you the best .
please, i want to hear from you again.
bestman
Old 02-19-2006, 18:14   #10 (permalink)
Member: 21937
Thanks Meter: 279
is this resistor can cuz power on not working ?
anyone know value ?
The Following User Says Thank You to TRABEL For This Useful Post:
Old 02-21-2006, 16:04   #11 (permalink)
Member: 21937
Thanks Meter: 279
ppl .................. HELP ... !!!!!!!!!
Old 02-22-2006, 11:14   #12 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
that is a voltage dependant resistor (varistor).
i think it is not important, from looking at the opertaion
Old 02-22-2006, 19:44   #13 (permalink)
Member: 21937
Thanks Meter: 279
i see... i'll try that bridge ... hope it'll help ....
Old 02-23-2006, 10:54   #14 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
no, please do not bridge! or phone will be not work properly!
if you bridge this component then phone will automatically power itself on when battery inserted
best to leave it out.
the operation is:
current is flow from voltage source "pwron".
if voltage there is small (nominal), R4460 resistor is high value. therefore voltage is apply at PWRONX pin of RETU (Via ESD filter). in this state, phone is OFF.
when switch is depressed, current will take the easy path through it to ground. now PWRONX pin of RETU is LOW and phone will power on.
R4460 (voltage dependant resistor) is used to protect ESD filter from large voltage spikes.
so please, just leave that component out if yo cannot find a suitable replacement.
Old 03-06-2006, 17:30   #15 (permalink)
Member: 148029
Thanks Meter: 9
dear
very good and very usefull
thanks
Page generated in 0.23388 seconds with 9 queries
