Old 08-02-2009, 05:40   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
1600 Lights not pwering OFF.
Hello, I got Nokia 1600 with Lights Fault. it was its Crystal ic problem. I replace the ic but after replacing the ic, now phone's lights never get OFF after 10 sec. i relace the IC again and again but still have problem.
when i switch power OFF then its lights become off otherwise its lights not powring OFF.
wat the problem in the Phone?
Thanx in Advance.
Old 08-02-2009, 08:01   #2 (permalink)
lavlesh jain's Avatar
Member: 666813
Thanks Meter: 88
check in setting it may be always on if yes than set it to normal
The Following User Says Thank You to lavlesh jain For This Useful Post:
Old 08-02-2009, 08:12   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,374
Thanx in Advance.
Bro.try it....
if not work...uem ic falt...............
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 08-02-2009, 08:47   #4 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
Originally Posted by ashad420 View Post
Bro.try it....
Yes, this is working solution for always light on. i have tested many sets.
thanks bro 'ashad' .
B.R.
habibuddin
Old 08-02-2009, 10:04   #5 (permalink)
Member: 788435
Sonork: 100.1672438
Thanks Meter: 25
hello change lcd ic 100%%%%%% working
Old 08-02-2009, 10:36   #6 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 239
in 1600 and similar models light IC triggered by UEM through a small transistor near the light IC, transistor act as a switch which gives a small voltage to the LIGHT IC to enable and disable the Light. if the Transistor damaged resulting no light or light turns on always. so try to check the transistor first.
Old 08-02-2009, 10:51   #7 (permalink)
fiazahmad's Avatar
Member: 263277
Thanks Meter: 139
change only transister problem will b solve
Old 08-03-2009, 06:55   #8 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Bro.try it....
Yes, problem solved.
Thanx very much.
1600 LCD Lights ok but Keypad lights not working Adil Mobiles Nokia Hardware & Hardware Repair 4 01-25-2010 19:19
China nokia 1600 lights off after power on mobifone Chinese Models & Cloned Phones 0 11-27-2009 08:52
Nokia 1100 display lights not power off astana2007 Nokia Digital Core Technology 4 ( DCT-4 ) 4 11-30-2008 20:02
6820 keypad light not going off eko Nokia Hardware & Hardware Repair 4 01-18-2007 13:21
D600, after flashing lcd light not turn off Sezamek NSPRO 5 06-03-2006 01:24
Page generated in 0.29170 seconds with 8 queries
