Old 09-25-2007, 20:40   #1 (permalink)
Member: 367928
Thanks Meter: 178
1600 sim not valid imei ok unlock with jaf,ufs,fusion still same
Sir 1600 was working while making call massage on secreen SIM NOT VALID
i full erase full flesh with pm use jaf and ufs same
i unlock with JAF,UFS and fusion still same i change sim ic also but still same pleaseeeee
Old 09-25-2007, 20:41   #2 (permalink)
Member: 367928
Thanks Meter: 178
ufa log
MCU Sw: V 5.54 16-08-06 RH-64 (c) NMP
PPM Sw: V 5.54 16-08-06 RH-64 (c) NMP IA
Prd.Cd: 0518260
Bpr.Cd: 0519858
Pro.Sn: MRB431288
HW : 5053
PCI :
UEM : 1314
UPP : 8705
RFIC : 0500
DSP : P05w06.v34
LCD : SDI:LD184v89
IMEI : 352761-01-846034-6
SLconf: 014-63-03531415927
SLprof: 000000000000000-2
SLvar : 00003527610184603400
SLaux : 0002C0DE
Provider: Not Found
#pw+ 886 091 502 452 004 +1#
#pw+ 027 333 246 535 647 +2#
#pw+ 258 335 076 625 147 +3#
#pw+ 019 893 735 750 201 +4#
#pw+ 424 547 141 227 250 +5#
#pw+ 493 547 514 177 552 +6#
#pw+ 712 450 236 036 463 +7#
Old 09-25-2007, 20:43   #3 (permalink)
Member: 367928
Thanks Meter: 178
jaf log
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.00
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.54
16-08-06
RH-64
(c) NMP
HW version: 5053
PCI version:
UEM version: 1314
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: SDI:LD184v89
PPM version: V 5.54
16-08-06
RH-64
(c) NMP
IA
ADSP SW version: V 5.54\n16-08-06\nRH-64\n(c) NMP\nia
Production serial number: MRB431288
Product code: 0518260
Module code: 0202178
Basic production code: 0519858
Flash code:
Order number: 0000000
Product specific data:
Long production SN:
ATO: m?????????????????????????????????????????????????
Default SN type: m?????????????????????????????????????????????????
IMEI plain: 352761018460346
IMEI spare to net: 3A 25 67 01 81 64 30 04
IMEI SV to net: 33 25 67 01 81 64 30 24 F6
Master Code: 1261517176
Phone type: RH-64, Software version: 5.54, Language Pack: IA
User code: 12345
Searching for saved ini...
Checking for file G:\Program Files\ODEON\JAF\JAF_RH-64.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0518260
Old 09-25-2007, 20:44   #4 (permalink)
Member: 367928
Thanks Meter: 178
fusion log
--> Start time: 1:14:56 PM
Reading phone information...
MCU Sw Version: V 5.54 16-08-06 RH-64 (c) NMP
IMEI Plain: 352761018460346
ASIC Type: Unknown
Unlocking...
Done.
--> End time: 1:15:03 PM
Note: In case phone signal is drop, flash the phone with 'restore' file.
Old 09-25-2007, 20:56   #5 (permalink)
Member: 176317
Thanks Meter: 14
put this code #pw+ 886 091 502 452 004 +1#
the mobile will be unloked
Old 09-26-2007, 04:10   #6 (permalink)
sanjeewa57's Avatar
Member: 170619
Thanks Meter: 13
i think it is not working u change uem & write rpl then u can sol ur problem
Old 09-26-2007, 04:20   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
may be its uem or version issue..........................!
Old 09-26-2007, 04:46   #8 (permalink)
Member: 268930
Thanks Meter: 23
Brother try to flash it with higher version as 6.00 or 6.01 may be it will work
Old 09-26-2007, 19:30   #9 (permalink)
Member: 577852
Thanks Meter: 2
unlock with UNIVERSAL box and then set difault it will be ok
i do this today
Old 09-26-2007, 21:19   #10 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
friend you must unlock it with mt-box or mxkey. other box cannot solve this problem
Old 09-26-2007, 22:42   #11 (permalink)
BHARGAV's Avatar
Member: 126000
Sonork: 100.1593044
Thanks Meter: 111
First Full Earise Flash
Now Flash Mcu,ppm,and Pm Next Unlock With Jaf.u R Set Will Be Unlocked
Old 09-27-2007, 08:20   #12 (permalink)
Member: 367928
Thanks Meter: 178
sit same may be uem any other solution.......
Old 09-27-2007, 08:49   #13 (permalink)
Member: 550886
Thanks Meter: 69
hi bro plzzzzzzzzz pm files wriat
Old 09-27-2007, 10:07   #14 (permalink)
Member: 367928
Thanks Meter: 178
already writred and unlocked sir read my all posts then reply
Old 10-07-2007, 20:52   #15 (permalink)
Member: 367928
Thanks Meter: 178
its uem problem i send it to nokia care i think it is best sol for 1600 to send it to nokia care in live condition
thanksssssssssss for help
1600 sim not valid??????? GSMLover2010 Universalbox 20 11-27-2009 09:52
1661 sim not valid ....imei is ok naeem_skg786 Nokia Hardware & Hardware Repair 4 11-03-2009 13:47
6680 sim not valid IMEI ok! Options Media Nokia Hardware & Hardware Repair 12 06-19-2009 20:41
1600 sim not valid? bavesore Nokia Digital Core Technology 4 ( DCT-4 ) 12 04-10-2007 21:35
1600 sim not valid manyosa Nokia Hardware & Hardware Repair 11 08-04-2006 19:46
Page generated in 0.25469 seconds with 10 queries
