04-15-2011, 11:31 | #1 (permalink) |
Junior Member Join Date: Sep 2010 Location: india,tamilnadu,coimbatore
Member: 1399550 Status: Offline Thanks Meter: 6 | 1616,1680-lcd light |
The Following User Says Thank You to lovelysheik For This Useful Post: |
04-15-2011, 11:48 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Hi Bros, you need to check the 12 display/light tracks carefully. It might be that a few of them are on the verge of breaking to create open circuit. Try and repair this and then test with other lcd. |
The Following User Says Thank You to ABUU YUUNUS For This Useful Post: |
04-17-2011, 12:22 | #3 (permalink) |
Insane Poster Join Date: Nov 2008 Location: Pakistan
Member: 907928 Status: Offline Sonork: Muhammad Nadeem Thanks Meter: 7 | i have 1280 and 1616 with lcd light problem both mobiles have damaged display but light was ok then i change display bot now light is not working of 1280 and 1616 have any body any solution but one thing all links are ok |
The Following User Says Thank You to nadeem101 For This Useful Post: |
06-08-2011, 06:07 | #7 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Quote:
use 100% og lcd or use special lcd available for 1616 mobile phone in market. if u will use 1661 lcd it will show reverse then use this code *#5514# Rotate 90 degree (CW) *#5513# Rotate 180 degree *#5512# Rotate 90 degree (anti CW) *#5511# Rotate to original screen this code for 1600 but work with 1616 and 1680 but when u power on mobile again u use code again. reply result | |
The Following User Says Thank You to sr8787 For This Useful Post: |
6110 LCD Screen | gsmxc | Nokia Hardware & Hardware Repair | 4 | 06-26-2004 06:03 |
BLUE light | Delfo | Nokia Hardware & Hardware Repair | 8 | 09-20-2002 04:28 |
6110 and 3210 LCD Screen | pks | Nokia Hardware & Hardware Repair | 12 | 04-24-2001 12:45 |
8890 LCD SCREEN | erikiiy | Nokia Hardware & Hardware Repair | 0 | 12-21-2000 23:37 |
6110 LCD Contrast Changing??? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-14-2000 18:52 |
