1616 flash ok but no power hi mates 1616 flashing is ok when i put cable it shows local mode but no on with battery even when i put charger nothing on display plz help to solve this problem........... br khm050 |
Do self test you will see lcd failed just replace lcd ur problem will be solved. br |
thanks to all i'll try and post result |
I CHECK IN SELF TEST IT SHOWS st_rtc_32khz=FAILED, ST_GPIO_LIGHT=FAILED |
plz somebody help to solve this problem |
what is the problem before flashing? |
it was dead............. |
chenge your screen 10000% ok |
i change the display but same no power |
thanxxxxxxxxxx laley |
i have same probmlome st_gpio_light fail |
can you upload scan log,90% it is lcd is fault,as you say lcd all ready changed, it may lcd light circuit is not ok so check lcd light circuit,few time it is power switch way are open,but it is very few times,i think sure it is lcd light circuit fault,so check this and post results |
change lcd but first cheak the lcd way with meter that the way ok or not if broken 1st try to repair and then change Lcd |
apply jumper [IMG]http://4.bp.********.com/-t00ArkkRg9Q/TdJ3Kqlf3PI/AAAAAAAAACM/Ylo_e200nb4/s1600/20110517-ejv4-32kb.jpg[/IMG] |
Try To CPU Narmel on Heat Problim Not Solved Try To Chang LCD And Post Result ...... |
