Old 11-27-2010, 13:49   #1 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
1616 flash ok but no power
hi mates 1616 flashing is ok when i put cable it shows local mode but no on with battery even when i put charger nothing on display
plz help to solve this problem...........
br
khm050
Old 11-27-2010, 13:58   #2 (permalink)
madni shah's Avatar
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Do self test you will see lcd failed just replace lcd ur problem will be solved.
br
The Following User Says Thank You to madni shah For This Useful Post:
Old 11-27-2010, 14:42   #3 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
thanks to all i'll try and post result
Old 11-28-2010, 09:32   #4 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
I CHECK IN SELF TEST IT SHOWS st_rtc_32khz=FAILED, ST_GPIO_LIGHT=FAILED
Old 11-28-2010, 14:54   #5 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
plz somebody help to solve this problem
Old 11-28-2010, 14:58   #6 (permalink)
albert maren's Avatar
Member: 185010
Thanks Meter: 160
what is the problem before flashing?
Old 11-28-2010, 15:03   #7 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
it was dead.............
Old 11-28-2010, 15:06   #8 (permalink)
Member: 185010
Thanks Meter: 160
chenge your screen 10000% ok
Old 11-28-2010, 15:27   #9 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
i change the display but same no power
Old 11-28-2010, 15:56   #10 (permalink)
Member: 586461
Thanks Meter: 12
thanxxxxxxxxxx laley
Old 06-01-2012, 12:04   #11 (permalink)
Member: 1766208
Sonork: RAJA22PAKISTAN
Thanks Meter: 3
i have same probmlome st_gpio_light fail
Old 06-01-2012, 16:06   #12 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 152
can you upload scan log,90% it is lcd is fault,as you say lcd all ready changed, it may lcd light circuit is not ok so check lcd light circuit,few time it is power switch way are open,but it is very few times,i think sure it is lcd light circuit fault,so check this and post results
Old 06-03-2012, 14:00   #13 (permalink)
Member: 1501291
Sonork: 100.1622368
Thanks Meter: 23
change lcd but first cheak the lcd way with meter that the way ok or not if broken 1st try to repair and then change Lcd
Old 06-03-2012, 14:04   #14 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 1,672
br
khm050
apply jumper
[IMG]http://4.bp.********.com/-t00ArkkRg9Q/TdJ3Kqlf3PI/AAAAAAAAACM/Ylo_e200nb4/s1600/20110517-ejv4-32kb.jpg[/IMG]
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 06-03-2012, 14:20   #15 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 456
Try To CPU Narmel on Heat Problim Not Solved Try To Chang LCD And Post Result ......
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 09:03
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-16-1999 13:20
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.40059 seconds with 8 queries
