09-04-2009, 18:45 | #1 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1105325 Status: Offline Thanks Meter: 1 | 1650 can on if use Power suplly but not battery |
01-26-2010, 17:09 | #7 (permalink) |
Freak Poster Join Date: May 2009 Location: Hazaribag Age: 35
Member: 1040838 Status: Offline Sonork: 123 Thanks Meter: 29 | i have a nokia 1650, change the uem ic or set is power on but imei is ?????? / or uem imei is 000000000000/ ask file kaise read kare / rpl file kaise write kare plese help............. |
01-26-2010, 22:53 | #11 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1209943 Status: Offline Sonork: [email protected] Thanks Meter: 3 | rehot uem................... |
01-27-2010, 21:17 | #13 (permalink) |
Junior Member Join Date: Mar 2009
Member: 998606 Status: Offline Sonork: nadir Thanks Meter: 2 | hellow brother if you have problem that your phone is power on on power suplie but not on battre first of all wash the downloding points of charging jeck if the problem is same then remove the locle mode resistos which are short to the center pin of battre cunector 1000% solve your problem |
6020 flashing OK showing test mode on screen with F-bus but not going to power on | makkah mobile | Nokia Hardware & Hardware Repair | 46 | 05-04-2010 06:13 |
6310 powers on only with power supply unit not with battery | kwikcell | Nokia Hardware & Hardware Repair | 0 | 01-19-2009 22:37 |
Mobile turns on with digital power supply but not on Battery. | jamsohail | Hardware Repair by brands | 4 | 05-28-2008 16:21 |
Mobile turns on with digital power supply but not on Battery. | jamsohail | Nokia Hardware & Hardware Repair | 0 | 04-26-2008 08:20 |
3220 Can On Ufs Box. Chaging Showing But Cannot On From Power Switch | NAVEED74 | Nokia Hardware & Hardware Repair | 3 | 06-02-2007 05:31 |
