06-17-2009, 10:28 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | 1661 1662 test mode ..::brother to wash battery conecter and then change battery and remove two rigestren to up the battery conecter so your problem has been solved::then so press thhhhhaaaannnnkkkkkssss... |
nokia 1202, 1203, 16611 1662 not charging, local mode, test mode solution | Dooha_Bd | Nokia Hardware & Hardware Repair | 19 | 01-05-2016 05:41 |
solutions can't local mode,test mode,normal mode after reflash in here | uwenk98 | Nokia Hardware & Hardware Repair | 30 | 07-27-2013 11:27 |
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested | /\/\A/\/| | Nokia Hardware & Hardware Repair | 14 | 07-11-2011 05:49 |
nokia 1202, 1203, 16611 1662 not charging, local mode, test mode solution | gsm junction | Nokia Hardware & Hardware Repair | 1 | 03-02-2010 18:47 |
flash,local mode,test mode,normal mode big problem need help | gsm_cdma_ufs | Nokia Hardware & Hardware Repair | 0 | 04-10-2009 10:50 |
