1661 help 1661 flashing ok but powar on plese help Getting MCU ID MCU ID: 0x2293 FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.700 Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.4A.00 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.4A.00 -> Revision: 0007 Loader size is 0x4C30; Loader chk: a1 Loader is ready... P-key nokia module version 01.02 MSID: 84DD098345009E90FE44AE9A23 MSID decoded: 3E4EBAE9001BEC4DA9000000 FAID: 248A27457F869B3E4908A2CF Operation took 0 minutes 12 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 0179FFFF... Erasing area: 017A0000 - 017EFFFF... Erasing area: 01F00000 - 01FDFFFF... Operation took 1 minutes 31 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 15 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh122_003.70mh Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.4A.00 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.4A.00 -> Revision: 0007 Loader size is 0x4C30; Loader chk: a1 Loader is ready... P-key nokia module version 01.02 MSID: 84DD098345009E90FE44AE9A23 MSID decoded: 3E4EBAE9001BEC4DA9000000 FAID: 248A27457F869B3E4908A2CF Operation took 0 minutes 6 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01250000 - 0125FFFF... Erasing area: 01260000 - 0174FFFF... Operation took 0 minutes 58 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 22 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-122\rh1220_nai03.70mh Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.4A.00 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.4A.00 -> Revision: 0007 Loader size is 0x4C30; Loader chk: a1 Loader is ready... P-key nokia module version 01.02 MSID: 84DD4DA46764604A156D42BABB MSID decoded: 3E4EBAE9001BEC4DAA000000 FAID: BF80E685F61034C15C903773 Operation took 0 minutes 7 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01750000 - 0178FFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 0 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 4 minutes 8 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-122, Software version: 03.70 IMEI: 351943032397354 Product Code: 0573014 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 5 seconds... Done! Done! Done! Changing mode... Failed!!! |
bro rehot or reball flash ic,,,and again try flash,,, try and post result |
1661 UPP 2293 Unlock OK by UFS or JAF and UB Not Working Upp 2293 |
1202 UPP 2293 Unlock OK by UFS or JAF and UB Not Working Upp 2293 |
mxkey SERVER: Not a valid IMEI number ( 3.4 rev not working plz help |
chk lcd prints on pcb also post selftest |
Try to Flash and Flash if no Luck..Rehot Flash IC |
contact service contact service in nokia 1661, |
