Old 03-18-2010, 19:46   #1 (permalink)
Arjun mishra's Avatar
Member: 426107
Thanks Meter: 64
Arrow 1661 not power on
1661 not power on
i flashed with ufs and jaf
no power please tell me the hardware solution
MCU ID: 0x2293
18:03:2010  15:18 -> FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
18:03:2010  15:18 -> FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
18:03:2010  15:18 -> First 16 bytes: 18:03:2010  15:18 -> FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
18:03:2010  15:18 -> Checking RAM for ALGO...
18:03:2010  15:19 -> Algo is ready...
18:03:2010  15:19 -> Checking FAID calculation...
18:03:2010  15:19 -> P-key nokia module version 01.02
18:03:2010  15:19 -> Done!
Phone Restarted...
18:03:2010  15:19 -> Current path C:\UFS\Nokia\Phoenix\Products\ changed to
18:03:2010  15:19 -> Changing mode...18:03:2010  15:19 -> Done!
18:03:2010  15:19 -> Phone Type:
18:03:2010  15:19 -> FILES SET FOR FLASHING:
18:03:2010  15:19 -> MCU Flash file: C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.700
18:03:2010  15:19 -> PPM Flash file: NONE
18:03:2010  15:19 -> CNT Flash file: NONE
18:03:2010  15:19 -> ADSP Flash file: NONE
18:03:2010  15:19 -> APE Variant file: NONE
18:03:2010  15:19 -> APE User Flash file: NONE
18:03:2010  15:19 -> PPM Flash file: C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.70el
18:03:2010  15:20 -> FILES SET FOR FLASHING:
18:03:2010  15:20 -> MCU Flash file: C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.700
18:03:2010  15:20 -> PPM Flash file: C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.70el
18:03:2010  15:20 -> CNT Flash file: C:\UFS\Nokia\Phoenix\Products\Rh-122\rh1220_nai03.70el
18:03:2010  15:20 -> ADSP Flash file: NONE
18:03:2010  15:20 -> APE Variant file: NONE
18:03:2010  15:20 -> APE User Flash file: NONE
18:03:2010  15:20 -> Backing up PM Field 208 as RPL...
18:03:2010  15:20 -> Setting local mode...
18:03:2010  15:20 -> Failed! Aborting!
18:03:2010  15:20 -> Failed to backup imei...
18:03:2010  15:20 -> MCU: 18:03:2010  15:20 -> C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.70018:03:2010  15:20 ->
18:03:2010  15:20 -> Booting phone...
18:03:2010  15:20 -> MCU ID: 0x2293
18:03:2010  15:20 -> BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
18:03:2010  15:20 -> Loader version: 04.46.0118:03:2010  15:20 ->  -> Revision: 0007
18:03:2010  15:20 -> Boot size is 0x09A8
18:03:2010  15:20 -> Boot is ready...
18:03:2010  15:20 -> FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
18:03:2010  15:20 -> FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
18:03:2010  15:20 -> First 16 bytes: 18:03:2010  15:20 -> FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
18:03:2010  15:20 -> Flash ID is 0x5422EC00
18:03:2010  15:20 -> Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
18:03:2010  15:20 -> Loader size is 0x7528; Loader chk: 1c
18:03:2010  15:20 -> Loader is ready...
18:03:2010  15:20 -> P-key nokia module version 01.02
18:03:2010  15:20 -> MSID: 84379C9D7059F79E8CBAE50E96
18:03:2010  15:20 -> MSID decoded: 3E4EBAE900CE3B23A9000000
18:03:2010  15:20 -> FAID: C9226729F576C607CD1F829F
18:03:2010  15:20 -> Operation took 0 minutes 12 seconds...
18:03:2010  15:20 -> Erasing...
18:03:2010  15:20 -> Found 4 interval(s) to erase
18:03:2010  15:20 -> Erasing area: 01000000 - 0100FFFF...
18:03:2010  15:20 -> Erasing area: 01010000 - 0179FFFF...
18:03:2010  15:21 -> Erasing area: 017A0000 - 017EFFFF...
18:03:2010  15:21 -> Erasing area: 01F00000 - 01FDFFFF...
18:03:2010  15:21 -> Operation took 1 minutes 0 seconds...
18:03:2010  15:21 -> Writing...
18:03:2010  15:22 -> Perm. Data Restore OK
18:03:2010  15:22 -> Operation took 0 minutes 19 seconds...
18:03:2010  15:22 -> Restarting MCU...
18:03:2010  15:22 -> PPM: 18:03:2010  15:22 -> C:\UFS\Nokia\Phoenix\Products\Rh-122\rh122_003.70el18:03:2010  15:22 ->
18:03:2010  15:22 -> Booting phone...
18:03:2010  15:22 -> MCU ID: 0x2293
18:03:2010  15:22 -> BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
18:03:2010  15:22 -> Loader version: 04.46.0118:03:2010  15:22 ->  -> Revision: 0007
18:03:2010  15:22 -> Boot size is 0x09A8
18:03:2010  15:22 -> Boot is ready...
18:03:2010  15:22 -> FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
18:03:2010  15:22 -> FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
18:03:2010  15:22 -> First 16 bytes: 18:03:2010  15:22 -> AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
18:03:2010  15:22 -> Flash ID is 0x5422EC00
18:03:2010  15:22 -> Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
18:03:2010  15:22 -> Loader size is 0x7528; Loader chk: 1c
18:03:2010  15:22 -> Loader is ready...
18:03:2010  15:22 -> P-key nokia module version 01.02
18:03:2010  15:22 -> MSID: 84FD1984CE4C85209F7BD2DE2D
18:03:2010  15:22 -> MSID decoded: 3E4EBAE900CE3B23AA000000
18:03:2010  15:22 -> FAID: A9131EBDDB29E683198B3030
18:03:2010  15:22 -> Operation took 0 minutes 12 seconds...
18:03:2010  15:22 -> Erasing PPM...
18:03:2010  15:22 -> Found 2 interval(s) to erase
18:03:2010  15:22 -> Erasing area: 01250000 - 0125FFFF...
18:03:2010  15:22 -> Erasing area: 01260000 - 0174FFFF...
18:03:2010  15:23 -> Operation took 0 minutes 36 seconds...
18:03:2010  15:23 -> Writing...
18:03:2010  15:23 -> Perm. Data Restore OK
18:03:2010  15:23 -> Operation took 0 minutes 19 seconds...
18:03:2010  15:23 -> Restarting MCU...
18:03:2010  15:23 -> CNT: 18:03:2010  15:23 -> C:\UFS\Nokia\Phoenix\Products\Rh-122\rh1220_nai03.70el18:03:2010  15:23 ->
18:03:2010  15:23 -> Booting phone...
18:03:2010  15:23 -> MCU ID: 0x2293
18:03:2010  15:23 -> BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
18:03:2010  15:23 -> Loader version: 04.46.0118:03:2010  15:23 ->  -> Revision: 0007
18:03:2010  15:23 -> Boot size is 0x09A8
18:03:2010  15:23 -> Boot is ready...
18:03:2010  15:23 -> FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
18:03:2010  15:23 -> FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
18:03:2010  15:23 -> First 16 bytes: 18:03:2010  15:23 -> AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
18:03:2010  15:23 -> Flash ID is 0x5422EC00
18:03:2010  15:23 -> Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
18:03:2010  15:23 -> Loader size is 0x7528; Loader chk: 1c
18:03:2010  15:23 -> Loader is ready...
18:03:2010  15:23 -> P-key nokia module version 01.02
18:03:2010  15:23 -> MSID: 84379C9D7059F79E8CBAE50E96
18:03:2010  15:23 -> MSID decoded: 3E4EBAE900CE3B23A9000000
18:03:2010  15:23 -> FAID: C9226729F576C607CD1F829F
18:03:2010  15:23 -> Operation took 0 minutes 12 seconds...
18:03:2010  15:23 -> Erasing Content Pack...
18:03:2010  15:23 -> Found 1 interval(s) to erase
18:03:2010  15:23 -> Erasing area: 01750000 - 0178FFFF...
18:03:2010  15:23 -> Operation took 0 minutes 2 seconds...
18:03:2010  15:23 -> Operation took 0 minutes 1 seconds...
18:03:2010  15:23 -> Operation took 0 minutes 0 seconds...
18:03:2010  15:23 -> Flashing Done!
18:03:2010  15:23 -> Operation took 3 minutes 29 seconds...
18:03:2010  15:23 ->
18:03:2010  15:23 -> After flash processing...
18:03:2010  15:23 -> Waiting for phone to boot...
18:03:2010  15:23 -> Reading...
18:03:2010  15:23 -> Phone type: RH-122, Software version: 03.70
18:03:2010  15:23 -> IMEI: 357997036)))))))))
18:03:2010  15:23 -> Product Code: 0573014
18:03:2010  15:23 -> Resetting PPC...
18:03:2010  15:23 -> Done!
Old 03-18-2010, 20:35   #2 (permalink)
hamada-almasry's Avatar
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,181
frist full erase
Then flash again
nokia 1661-2 power on problem WHED Nokia Hardware & Hardware Repair 5 02-19-2014 19:35
6030 mobile not power on, on battery and working fine on power supply kashif_khatri Nokia Digital Core Technology 4 ( DCT-4 ) 1 09-19-2009 03:57
7370 power on on ufs but not power on battrey dereje Nokia Hardware & Hardware Repair 0 05-26-2009 10:25
G5600 not powers on with sim while without sim powers on :( need help the_frightener LG 1 03-20-2005 06:18
t100 not power on after flash, not power on when original cable is plug GYZMO VLSI, Conexant, Skyworks and Old Models 8 01-07-2004 00:34
Page generated in 0.24573 seconds with 8 queries
