09-10-2008, 15:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Nokia 1200 power problem Thank. |
The Following User Says Thank You to .::MD_AKTER::. For This Useful Post: |
09-11-2008, 11:00 | #4 (permalink) |
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Here is jaf log:- Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.23ic CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.23ic CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh1050_nai5.23ic ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.230 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 843D7D9807B468A4FFDC4C496E MSID decoded: 3E4EBAE900D53397AA000000 FAID: BE8F08A3542C733AF4E2B842 Operation took 0 minutes 11 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 1 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh105_05.23ic Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 848574C93C3042FEB24C52FA4C MSID decoded: 3E4EBAE900D53397A8000000 FAID: FD8186511A5D42E72CBE702D Operation took 0 minutes 11 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 22 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\1208 ver 5.23\rh1050_nai5.23ic Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84FCEB189F5963944B78170DBB MSID decoded: 3E4EBAE900D53397A9000000 FAID: 008B7B2787648FD45D0F21A2 Operation took 0 minutes 10 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 2 minutes 35 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 5.23 IMEI: 356382023116819 Product Code: 0549920 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 5 seconds... Done! Done! Setting local mode... Reading imei... IMEI/ESN: 356382023116819 Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! |
09-11-2008, 12:53 | #7 (permalink) | |
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
nokia 1200 power on/of ways | khanmobiles0003 | Nokia Hardware & Hardware Repair | 7 | 07-21-2011 12:21 |
nokia 1200 power way. | nangia khan | Nokia Hardware & Hardware Repair | 1 | 03-22-2010 07:55 |
nokia 1200 power way. | nangia khan | Nokia Hardware & Hardware Repair | 1 | 03-22-2010 07:49 |
1200 power problem | kenecee | Nokia Hardware & Hardware Repair | 3 | 12-16-2009 08:29 |
