Old 07-04-2004, 10:09   #1 (permalink)
Member: 27606
Thanks Meter: 15
2 x 6210 network problem
first can't get network,try with manual sirch it can't find it
second gets network but sometimes when I wan't to have a call network is gone.
I didn't do anything with it so I wiil change PA and can i do thing like in 3310,8210 with antenna switch with two little wires
Old 07-04-2004, 23:10   #2 (permalink)
goanga's Avatar
Member: 57035
Thanks Meter: 70
Yes the trick with the "little two wires" works on 6210 you can do that to exclude the antena switch fault . Clean antena conectors/ resold ( CHANGE ) PA ! on the second one ! If it doesn't work try to resold with flux ( CHANGE ) the IF IC ! GOOD LUCK !
Old 07-05-2004, 02:09   #3 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@Destructor
Most proper fault on your 6210's in this case is your COBBA pads. The COBBA on the 6210 have a serous flaw in print circuit layout. The grounding leg to the COBBA very often oxidize due to the fact that it is not proper soldered from factory and by time it oxidize and will loose connection. Have seen this fault on scores of 6210.
Check COBBA and let us know if it's this fault.
Regards
Old 07-05-2004, 20:45   #4 (permalink)
Member: 27606
Thanks Meter: 15
ok I will post results in few days
Old 07-28-2005, 20:22   #5 (permalink)
Member: 109294
Thanks Meter: 22
Hi 2 U all!!
Originally Posted by GSM Coolhawk
@Destructor
Regards
Cobba pads are nasty, although, today I realized only NOT CONNECTED pads are missing on my 6210. I was so glad! I looked in the service manual. It has plenty of not connected pins. Pads from those were all missing from the board, I thought I'm never gonna B able 2 repair this one again. Now, I got hope! But still, without COBBA, phone shows CONTACT SERVICE. I don't have a 6210 COBBA, but a 3310. Is it compatible? I have no ideea. If I look at the codes written on them, looks like they're far from similar in my opinion. Please help beginners! Like me
Cheers!
Oh, i forgot, I noticed that COBBA has a LOT of pins grounded. Which one R U talking about?
6210 network problem pls help Surej Nokia Hardware & Hardware Repair 2 01-16-2003 10:54
6210 network problem patrynio Nokia Hardware & Hardware Repair 4 01-13-2003 13:06
Nokia 3330 and 6210 network problem tgsm Nokia Hardware & Hardware Repair 7 10-12-2002 01:38
6210 network problem DJ_Andy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2002 16:27
6210 network problem MadPhone Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-19-2001 22:07
Page generated in 0.22293 seconds with 9 queries
