08-20-2016, 03:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | 206 not detect handsfree i try all possible things but same change jack short 2 points rehot cpu but same |
08-22-2016, 17:57 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | hi bro , how are you ? here I share a solution . frist try to replace marker ntc . is't a 18v/30v ntc . u can find it in another set . if not solve then try to replace marked resistor . it's a 2.2k resistor. handfree plug detection signal goes to G10 pin in cpu via this parts . if still not solve then u should check track between handfree jack pads to cpu or replace cpu . post result. |
