09-29-2006, 23:41 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | black display is anoyher fault , i think that , wash pcb with ctc , if u prob solve , otherwise u do flash , some time contact service is fault of cleaning |
09-30-2006, 22:52 | #8 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 57502 Status: Offline Thanks Meter: 2 | Rishee, Try to full flash using XPmobile2002 or Rolis Flasher. Then run Nokia Tool to update faid, clear simlock, and change IMEI. If you still find something wrong with the IMEI# (example: different IMEI# and ORIGINAL IMEI#), phone should be CONTACT SERVICE or NO NETWORK. Then you can try to flash the phone using UFS3 with firmware version 5.84. Phone will be OK. But if the phone is still not OK, replace the FLASH IC. GOOD LUCK. Rgds, dareevil |
Nokia 2100 Black Scratchy Screen At the time of Flashing... | amit123 | Nokia Hardware & Hardware Repair | 3 | 07-27-2009 06:50 |
2100 Full Display Track Soln | agaalias | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-06-2008 14:26 |
2100 No display Even after flash | celluniversal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-03-2008 09:04 |
2100 its display not working | zakir375 | Nokia Hardware & Hardware Repair | 6 | 08-15-2007 07:09 |
2100 No display and Vibrating When Insert battery | khansa | Nokia Hardware & Hardware Repair | 7 | 05-11-2006 13:16 |
