2100 contact service.. i have a problem with nokia 2100 contact service.. i do: - erase file - flash with MCU and PPM V.5.84 - change imei - UI setting but nothing happen.. still CONTACT SERVICE... Cobba OK.. anybody help me plz... thanx...:(:(:( |
try with only pm files and flash pm after ui setteing |
flash with dct3 eeprom then update in noktool unlock.. ... |
flash with geoflash..... |
With Ufs Please Do This ( This May Ok Your 3310 2100 And 3330) (1) When You Have 2100 Slect 3610 Uncheck The Autoproduct And Erase By Address ( Start Address Is 00200000 End Address 005fffff) (2) Flash With Any New Version 2100 (3) Set Faid (4) Init Simlock (5) Rebuild Imei (6) Reset Userlock (7) Full Factory Default Your Phone Is Ok In Case Off 3310 Contect Service You Slect 3330 Then Erase B/r Tpc Hall Road Pakistan Ikhlaq Ahmad |
get info irf cobba is 00000 it si hardware if cobba is serial ok then try a softwre flash a phone write pm chage imei full factory default |
Plz write pm file maybe your problem is slove ok |
i have tried this many times in 2100.commonly its a software.just flash it using GEOFLASH(dct3 flasher).then update it using NOKTOOL.update IMEI,unlock it.reset settings...100% working |
its very good in geoflash.nd noktool...it will surely solve cntct serv in 2100 |
2100 contact service solution 1 Attachment(s) Quote:
1- totally erase the phone 2- manualy flash the phone with PMM file (attached ) 3- change IMEI 4- perform total UI options HAFIZ MOBILES enjoyyyyyyyyyyy!!! |
read info Quote:
its the same with 2100 Quote:
Guaranteed Solution Flash Mcu With 49_ Ppm 490 Then Do Ui, Rebiuld Imei Reflash Mcu With Language Pack 49a And Ppm With Language Pack 49b Do Ui, Rebuild Imei All Ok |
Sometimes bad cobba reads ok not always 00000 ... so if software doesnt work at all than try changing cobba again ,, I have had many sets solved by doing so ,, but first u must try repairing with FULL ERASE FULL FLASH PMM REBUILD IMEI UI SETTINGS FAID ... if ng works than change cobba again AK |
