02-12-2007, 14:49 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 366974 Status: Offline Thanks Meter: 31 | 2100 contact service.. i do: - erase file - flash with MCU and PPM V.5.84 - change imei - UI setting but nothing happen.. still CONTACT SERVICE... Cobba OK.. anybody help me plz... thanx... |
02-12-2007, 19:58 | #5 (permalink) |
Freak Poster Join Date: May 2005
Member: 147811 Status: Offline Thanks Meter: 27 | With Ufs Please Do This ( This May Ok Your 3310 2100 And 3330) (1) When You Have 2100 Slect 3610 Uncheck The Autoproduct And Erase By Address ( Start Address Is 00200000 End Address 005fffff) (2) Flash With Any New Version 2100 (3) Set Faid (4) Init Simlock (5) Rebuild Imei (6) Reset Userlock (7) Full Factory Default Your Phone Is Ok In Case Off 3310 Contect Service You Slect 3330 Then Erase B/r Tpc Hall Road Pakistan Ikhlaq Ahmad |
The Following 3 Users Say Thank You to ikhlaq For This Useful Post: |
02-18-2007, 07:56 | #8 (permalink) |
Freak Poster Join Date: Feb 2007 Location: pilipinas
Member: 445609 Status: Offline Thanks Meter: 27 | i have tried this many times in 2100.commonly its a software.just flash it using GEOFLASH(dct3 flasher).then update it using NOKTOOL.update IMEI,unlock it.reset settings...100% working |
The Following User Says Thank You to zultopo For This Useful Post: |
02-18-2007, 08:17 | #10 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Lahore, Pakistan
Member: 234653 Status: Offline Thanks Meter: 83 | 2100 contact service solution Quote:
1- totally erase the phone 2- manualy flash the phone with PMM file (attached ) 3- change IMEI 4- perform total UI options HAFIZ MOBILES enjoyyyyyyyyyyy!!! | |
The Following User Says Thank You to hafizjee For This Useful Post: |
02-18-2007, 13:18 | #11 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Lusaka,Zambia,Africa Age: 49
Member: 365744 Status: Offline Thanks Meter: 54 | read info first of all try to read info if the cobb is 0000 then its hardwaer but if it has numbers then get any new ver erse flash it and dont 4get to put pmm and then rebuld IMEI then UI setting the phone should be ok .but if u cant manage to read in jst do the second thing ve told u.remember to post the results |
The Following User Says Thank You to Temani For This Useful Post: |
02-18-2007, 14:38 | #12 (permalink) | |
Insane Poster Join Date: Mar 2006
Member: 249464 Status: Offline Thanks Meter: 4 | Quote:
02-23-2007, 23:15 | #14 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Guaranteed Solution Flash Mcu With 49_ Ppm 490 Then Do Ui, Rebiuld Imei Reflash Mcu With Language Pack 49a And Ppm With Language Pack 49b Do Ui, Rebuild Imei All Ok |
The Following User Says Thank You to ::gsmcoder:: For This Useful Post: |
02-24-2007, 01:46 | #15 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | Sometimes bad cobba reads ok not always 00000 ... so if software doesnt work at all than try changing cobba again ,, I have had many sets solved by doing so ,, but first u must try repairing with FULL ERASE FULL FLASH PMM REBUILD IMEI UI SETTINGS FAID ... if ng works than change cobba again AK |
The Following User Says Thank You to mike67 For This Useful Post: |
2100 contact service | Byte | Nokia Hardware & Hardware Repair | 45 | 12-17-2004 18:41 |
2100 Contact Service | kiss89 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 10-03-2004 08:12 |
2100 contact service with griffin | djyash | Griffin | 39 | 01-28-2004 12:09 |
Nokia 2100 Contact service | thunoy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-10-2003 09:46 |
2100 contact service new flash chip[sharp] | drnele | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 08-05-2003 19:10 |
