08-21-2005, 18:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 42
Member: 168346 Status: Offline Thanks Meter: 20 | 2100 contect service i have a nokia 2100 with contect service i Flash it flashing is ok but contect service is not remove. kindly somebody help. thanks in advance |
08-21-2005, 18:49 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | fullflash mcu+ppm+eeprom, better use dct3 flasher (geoflash) and LPT port cable to make flash and set fald, rebuid imei, unlock use nooktool18 COM port cable. if problem not slove heat COBBA with some of good flux or change it with new one is better. |
08-22-2005, 11:17 | #6 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: PORT HARCOURT,NIGERIA. Age: 54
Member: 36906 Status: Offline Thanks Meter: 1 | solution Quote:
Cheers. | |
10-27-2005, 18:39 | #9 (permalink) |
Registered User Join Date: Sep 2005 Location: pakistan Age: 48
Member: 184762 Status: Offline Thanks Meter: 6 | 2100 osn 6565656 sorry for my bad engkish in advance use ufs3 do setup by setup (1)erase flash (2)start adress 0020000 (3)end adress 0400000 (4)reflash with new version (5)after flashing rebuild imei with difrent imei (6)full ui settins now if ur imei is not rebuield but ur set is 101% ok and ur imei and osn are same tested: regards mughal |
10-27-2005, 18:55 | #10 (permalink) | |
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
@tolowo all about flasher and flashes is now available for free here: w w w . g s m m i n d . c o m | |
10-27-2005, 19:17 | #11 (permalink) | |
Member: 184762 Status: Offline Thanks Meter: 6 | osn 6565 problem Quote:
erase flah start adress 0020000 end adress 0400000 reflash withe latest version rebuilb imei with difrant imei full ui setting if ur imei is not changed but ur imei and osn waill same and ur phone is 101% ok tested regards mughal | |
01-19-2006, 13:29 | #13 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Hi friend flash your phone with ufs,twister,powerflasher or griffin box the mathord is same 1st flash phone with 2100 mcu+ppm+pmm (eeprom file) when flashing complete rebuild imei after that use UI Option's the set is ok 1000000000000000% my best wishes with u Omairbutt786 |
contect service 2100 | DYNET | Nokia Hardware & Hardware Repair | 6 | 01-29-2007 05:00 |
T Mobile C 332 contect service provider | baraka42 | Motorola P2k | 3 | 12-24-2002 12:21 |
3350 insert sim contect service version 5.01 | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-17-2002 09:37 |
all NOKIA contect service | gsnbhagawan | Main Sales Section | 0 | 09-09-2001 13:32 |
8850 contect service | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-11-2001 02:10 |
