07-08-2004, 19:57 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | Hi Yes you can there is apparently a patched flash file that is available or you can change the flash IC to a 5210 one then reflash complete flash and then write whatever IMEI you want Regards D. |
07-09-2004, 19:40 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | you can change it but becarefull do you have nokia software (DCT 3 Flasher, Nokia tool) ? if you do not have, i think you can use the software and down loading it from http://www.fashionmobile.galeon.com/programas.htm download the Xpmobile 2002 and use DCT3 M-bus cable, you can change the IMEI in the section PHONE SETTING Enjoy it, but becarefull |
07-10-2004, 01:01 | #4 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks Meter: 7 | Quote:
thanx | |
07-10-2004, 20:40 | #5 (permalink) | |
Member: 71273 Status: Offline Thanks Meter: 14 | @ etscellular Quote:
Use Xp Mobile 2002, it compatible to your phone or you can use UFS-3. | |
07-17-2004, 00:11 | #7 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | greetings etscellular my friend MOST or i can say 95% of 2100 having OTP flash chips :eg something like SHARP so to CHANGE any DESIRED imei will FAIL only way in theory to do it would be CHANGE "FLASH ROM" itself <so trying all imei tools WILL fail,wasting time> try to READ carefully what " dmd " gota say and im certain your problem can be SOLVE immediatly have a nice day bye |
07-18-2004, 00:56 | #9 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | hi @mansoor DMD is a "NAME OF A HELPFULL MEMBER on forum" maybe U NEED to READ ABOVE clearly and undertstand what is said and also MOST important--->WHICH MEMBER said it in this case 2ND reply was MEMBER dmd keep well bye man |
07-24-2004, 06:44 | #10 (permalink) | |
Junior Member Join Date: Jul 2004 Age: 44
Member: 71626 Status: Offline Thanks Meter: 0 | Quote:
07-24-2004, 11:05 | #11 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | you don't need to do any harware changes 1.fullflash with knok or rollis(if not fullflash you can't change imei) 2.write new imei with noktool 18 |
09-01-2004, 11:02 | #13 (permalink) | |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | 2100 imei patch Quote:
where can I get that patch and what should i do then ? hope to hear soon have fun mOLY | |
09-10-2004, 02:23 | #14 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | using UFS-3 1-erase flash 2-write MCU + PPM 3- change IMEI 4-set FAID 5-full factory if X and 0 appears instead of operator logo you can use nokia tool by rolis to do steps 3,4,5. good luck |
Nokia 2100 IMEI rebuild/change | AssenBG | Exchange Section | 9 | 08-30-2005 10:39 |
Can we change 2100 imei ? | raino | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-18-2003 16:28 |
Nokia 2100 imei solution. | Firecell | Main Sales Section | 0 | 11-03-2003 10:02 |
2100 imei | Saulyss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 37 | 08-16-2003 11:41 |
2100 Imei Can't Be Change!! | hooi76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 04-20-2003 07:33 |
