Old 07-02-2004, 13:03   #1 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 77
2100 keypad LEDs still lighting
the phone was droped on the ground !
I rehot the PCB and clean It I arrived to revive It .
The phone workes but the keypad LEDs sill lighting .
What can be the problem please ?
Old 07-02-2004, 13:33   #2 (permalink)
~:Sujyot GSM Zone:~'s Avatar
Member: 48238
Sonork: 100.54361
Thanks Meter: 396
put a jumper from display led to keypad led
Old 07-02-2004, 19:21   #3 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 77
Did you explaine more that !
I said that the Keypad LEDS still lighting for all the time .
Old 07-02-2004, 19:55   #4 (permalink)
Member: 44625
Thanks Meter: 36
The ringer n LED controller IC may be bad. Try changin it.
Old 07-02-2004, 22:03   #5 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
try to change the UI_IC's, but before you change it, it will good if you lookin the resistor in the round of the UI_IC's, because it will be more safety. thx
~~~~~~~~~~~~~ Unggul ~~~~~~~~~~~~~~~~~~
############# INDONESIA ###################
Old 07-02-2004, 22:48   #6 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
i have same problem amstill unable to solve them i changed the ringer/light vibrator ic no success
Old 07-03-2004, 22:19   #7 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 77
I will test the keypad IC and replay .thans !
Old 07-06-2004, 11:15   #8 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 235
try to change ui module 100% tested
Old 07-06-2004, 12:30   #9 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 77
Whati's this UI module please ! where on the board ?
Old 07-06-2004, 20:29   #10 (permalink)
Member: 44625
Thanks Meter: 36
Here's where u can get service manuals:http://web218.bces-3040.de/nokia/flash_unlock.php . Download the manual and learn which Ic controls the LEDs, keypad, ringer and buzzer. Change it. This ic is also called UI(user interface) IC. Please don't waste time any more time asking where this IC is. If after changing still u have probs u can ask for more hints. Post the results here.
Old 07-07-2004, 14:50   #11 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 77
I have changed the Ui from an other board and It's all ok thank you very much !!
Old 07-07-2004, 21:26   #12 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
KBD leds are controlled by the same IC as keboard leds,I don't remeber it's name and number.
But it have two inputs and two oitputs. Inputs are enable lcd light and enable keyboard light.
It also have two inputs (LCD and KBD) current adjast. If one of these (current setting) resistor is damaged then you will recieve no light.
There are also protective resistors... They can also be faulty.
Old 07-07-2004, 23:39   #13 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Angry
Originally Posted by azampk
don't chek chang keypad ic man
************Azam******************
checking the IC's is the best tricks to repair the phone, so what do you do if the IC's changed but the problem can't solve??????????????????????????????
It means probably the resistor arround the UI Ic's is bad or lost. So checking is the best way man...!!!
In the Service manual book there isn't shown what do you do "KEY PAD IC"!!!
Please be a professional man...!!!!!!!
Old 07-08-2004, 19:51   #14 (permalink)
Member: 44625
Thanks Meter: 36
Its true that resistors can get damaged, but in most cases changing the IC solves the prob.
6600 Keypad LED On But LCD no LED+no display s1emens Nokia Hardware & Hardware Repair 9 05-28-2009 21:34
6300 blue led still light igrek Nokia Hardware & Hardware Repair 1 12-12-2007 05:01
6680 with no displays led and no keypads led JeAn-cLeM Nokia Hardware & Hardware Repair 2 07-17-2006 22:42
2100 keypad light dont work..... RAHUL12345 Nokia Hardware & Hardware Repair 2 07-01-2004 11:22
Page generated in 0.33766 seconds with 8 queries
