2100 no network pls can someone give me a detailed solution for 2100 no network problem |
Maybe change PA? :D |
Also try Update FAID with Rolis soft. |
also check the antenna switch |
First Identify its HW or SW, try manual network search if found then prob its SW. |
check the txirq first, then check the txirq from hagar to hagar. plz use the scematic. the signal problem is not only in pa or antena swicht, but the cobba ic and ccont ic can make the signal drop. |
1.weak signal 2.flactuating signal 3.fake signal 4.logo only 5.indicator only 6.manual signal only 7.one bar signal only what signal problem? there are almost 12 kinds of signals problem, ill wait for u to tell witch one? or ill try to drop by ASAP to post all the posible technic i know. respect coming from me |
Tr -FAID By Rolis -Change PA -Change Antena swicth ........ReGards:D |
hi chukky many times i do it go and falsh first than if u got logo only than open with help nokia rolis soft ware here u can change imiei also {ap date faid } if result is same than come on cooba {light heat}than check again if same than replace cobba but should be ok . if not come step by step {hagar pa intina sw try its 100> true do and tell me bye |
Quick set faid. or flash it!! |
I ve flashed it and still the same prob, no network at all, and phone arbitralily switches off...I ve made a phone call, but then no network since then...I am suspecting ccont..Any ideas? |
I loaded software nd updated faid then replaced ant swt, pf and cobba but the singnal dropping doesnt solve. |
no network Check the B+ of PA&RX section(filters,capacitors,resistors,etc)&cct may be open. |
FAID By Rolis -Change PA -Change Antena swicth replace cobba |
Some time CPU and flash chip IC can meke phone no network BR |
