Old 04-12-2004, 15:34   #1 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry 3310 dead
3310 No power on even not charging battery cannector point +B to gnd short whats a problem?
thanks
shri
Old 04-12-2004, 18:28   #2 (permalink)
Member: 44658
does power button, click on/off?
have you tried flashing the phone?
Old 04-12-2004, 20:30   #3 (permalink)
Member: 32284
Thanks Meter: 4
Hi!
Simple check...with a DCpower supply with current indication apply 3.8V to +and - of the phone...if consumption is 30mA or high U need to flash ..
If its less...U have hardware problem...
Good luck!
Big8
Old 04-13-2004, 06:29   #4 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
on/off switch ok CCONT & PF remove but still showing short circuit + - short
i want 3310 circuit diagram where i download or show circuit daagram
thanks
shri
Old 04-13-2004, 06:46   #5 (permalink)
Member: 12724
Thanks Meter: 30
if + - are shorted :
may be some capacitors are shorted.there is more than 18 capacitors in this lines!
If you removed chaps,ccont and pf and still short,you need to check many little parts.
just serch for 3310 service manual on forum.but some times MAD cause this fault.
Old 04-13-2004, 07:08   #6 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry
i want 3310 circuit diagram where i download or show circuit diagram
thanks
Old 04-13-2004, 07:48   #7 (permalink)
Member: 61249
Hi man,
There is one attachement in PDF format.
Download it and open it by adobe reader.
Best of luck.
Jem
Old 04-14-2004, 15:34   #8 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
remove P.A first.
Old 04-14-2004, 15:37   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
check backlight, ringer, vib. I.C, check leds for shorts.
Old 04-14-2004, 16:36   #10 (permalink)
Member: 12724
Thanks Meter: 30
I cant understand relation between buzzer,vibra and led short with VBAt to ground short!
Dont waste ur time with this because:
Led's to groun have R486 and R437 .
Vibra has link to N400 Pin 16 and VB
Buzzer VB and N400 pin 6
Just remove N400(UI driver) CCONT , Chaps,PA,C575,C274,C228,C202,C235 and some other capacitor on VBAT-GND line
Old 04-15-2004, 04:59   #11 (permalink)
Member: 46212
remove all ics and see the shorting
mainly pf ccont chaps, hager ic
if not solve there may be internal sorting
swap phone
Old 04-16-2004, 15:50   #12 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
Buzzer PADS can be shorted to ground, also VIB PADS, LEDS could have direct connection to ground befor track reaches the I.C .
trying to help, beside i had these problems befor.
thanks you
Old 04-17-2004, 09:58   #13 (permalink)
Member: 12724
Thanks Meter: 30
thanks you
Dear mansi ,Buzzer ,Led,vibra olnly can short to ground in this case,N400 (UI driver) short to ground not else.
This parts are not in VB lines.If you see any short to ground in Vibra or buzzer N400 has shorted,If you move N400 you will see short gone!
Old 04-25-2004, 06:05   #14 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
thanks for all
i replace the CCONT ic
But after replace CCONT ic on the power switch CCONT ic heat
thanks
shri
Old 04-25-2004, 13:06   #15 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
hi shri,
there is some mistake in replace ccont. reball and relace it again or replace with new one ccont. then check output of ccont. vbb-vcore- vxo..
w.b.r.
3310 dead or not dead amralkareem Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-28-2006 17:34
3310 dead can flash ok but dead mobilemafia Nokia Hardware & Hardware Repair 12 06-02-2004 00:06
3310 dead after wrong flash, after buckup it not turn on????? Oleg_ Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-18-2002 12:35
3310 DEAD plz help Ziba Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-08-2001 10:04
3310 dead after 1 min. to 2 hr. gsnbhagawan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-06-2001 12:02
Page generated in 0.19882 seconds with 10 queries
