Old 01-10-2009, 19:26   #1 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 797
Question 2100 vibrates conitnously with leds ???
nokia 2100 vibrates conitnously with led
what to do
the phone is short
please help me what to do with this ??
thanks in advance
regards
dapinder
Old 01-10-2009, 19:40   #2 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 114
first wash full pcb with petrol and leave to dry, or dry with rework station,. check phone...
if not work problem likely from PA(power amp) or UI ic
replace UI chip first then check fone, if not work PA
Good luck...
Old 01-10-2009, 20:04   #3 (permalink)
Member: 145082
Thanks Meter: 797
the client told me
he used some other battery for this
and the phone got off with a blink and vibration
i think he used a high voltage battery
what to do ??
thanks in advance
Old 01-10-2009, 20:10   #4 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,034
Originally Posted by dapinderjit View Post
the client told me
what to do ??
thanks in advance
clients never say truth .. they like to make excuse
Old 01-10-2009, 20:14   #5 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 114
do this
If High volt damage. first remove ccont ic (power ic) read +ve and gnd with multimeter, if short is gone, change ccont ic and all will be ok... if short remains change PA
Good luck..
Old 01-10-2009, 20:23   #6 (permalink)
Member: 145082
Thanks Meter: 797
cleaned the pcb and dried it with rework station
no help !!!
yes its 100 % high voltage damage
have i need to reball the power ic or rebaal will do
Old 01-10-2009, 22:08   #7 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 114
Do this
Good luck..
Do this as post result,
~ Remove CCont (power ic), then clean ball graid to resolve shorts
~ Read possitive and negative of pcb pads with Multimeter for shorts
~if no shorts, Replace CCont with new one .
problem will be solved...
Bluetooth Vibrating Bracelet with Screen IPMART ipmart WebShop 0 02-16-2009 13:00
2100 vibrating divama4n Nokia Hardware & Hardware Repair 1 11-28-2008 09:58
2100 vibrator problem ZEBUN Nokia Hardware & Hardware Repair 1 12-28-2006 22:36
2100 Vibrates When Battery Inserted jamohaki Nokia Hardware & Hardware Repair 4 09-15-2005 07:53
Two Alcatel XG1 one with LCD circuit problem .THE 2nd one with LED $ key pad prbm holyspirit's BF, BG, TH, BHx Series 0 08-01-2005 19:15
Page generated in 0.31522 seconds with 8 queries
