Old 11-12-2004, 10:46   #1 (permalink)
shiljo's Avatar
Member: 6464
Thanks Meter: 6
2300 charging problem
Hello!
Someone asked about same problem before,without answer...so,I want to ask again did anybody found solution
When charger is connected,phone shows only battery icon on LCD.
I checked all components from charger line,tried with writing PM,flashing...
Phone is new,not used,but I am not sure does somebody worked something with software on this phone.
Somebody knows what else to try?
Thanks in advance!
Regards
Shiljo
The Following User Says Thank You to shiljo For This Useful Post:
Old 11-12-2004, 13:55   #2 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
yes.. had same problem in 1100/2300 even tried change UEM, still unsolved... maybe someone solved !!
Old 12-05-2004, 10:35   #3 (permalink)
Member: 85008
Thanks Meter: 4
Originally Posted by shiljo
Hello!
Thanks in advance!
Regards
Shiljo
on the right side of the battery terminals there lies on diode change it and the problem will be solved its common fault with 1100 also,face same problem and it was rectified by same method
Old 12-05-2004, 19:29   #4 (permalink)
Member: 84028
can u pls show it by pics
Old 02-11-2006, 08:33   #5 (permalink)
.:.GSM-ANGEL.:.'s Avatar
Member: 69984
Thanks Meter: 170
Please help .... Please Help
I have a strange problem.... please please help me..
I have Nokia 2300, when trun it on it works for some secnds then a icon like car appears and it goes off.... (Wonder)
A@DIL
Old 02-11-2006, 16:49   #6 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
A@DIL
i also need the help with picture.........
Old 06-10-2008, 13:55   #7 (permalink)
Member: 738815
pls helf 2300 no lcd light
Old 06-10-2008, 13:56   #8 (permalink)
Member: 738815
no lcd light i will change lcd
2300 charging problem deann Nokia Hardware & Hardware Repair 0 06-15-2008 12:47
Nokia 2300 charging problem ranjit2003 Nokia Hardware & Hardware Repair 1 07-13-2006 17:51
1100/2300 charging problems mattakins Nokia Hardware & Hardware Repair 2 11-06-2005 13:13
2300 Not Charging Problem chwaseem Nokia Hardware & Hardware Repair 1 05-05-2005 05:21
2300 charging .:RAGE:. Nokia Hardware & Hardware Repair 0 12-28-2004 20:30
Page generated in 0.24330 seconds with 9 queries
