Old 04-10-2005, 09:33   #1 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
2300.dead
nokia 2300 flashing ok but no power and local mode, write pm failed what can i do. please help me
Old 04-10-2005, 20:22   #2 (permalink)
ashok2's Avatar
Member: 81612
Sonork: ashok2
Thanks Meter: 2
2300dead Chek lcd connactor & ree flashing v5.62thenok
Old 04-10-2005, 20:28   #3 (permalink)
yasirmcp's Avatar
Member: 36825
Thanks Meter: 11
if u conect with soft it showing local mode?????
after removing from cable not power on?????
i think it is the problem of the flash ic?u read u r rpl and change the flash ic,
otherwise u need to change the power ic also
after flash ic changing flash the phone phone will on 100%
Old 04-10-2005, 20:29   #4 (permalink)
yasirmcp's Avatar
Member: 36825
Thanks Meter: 11
what the wrong think u post here.phone dead why to check lcd conector???????????????
Old 04-10-2005, 21:12   #5 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 66
hi,
contact me,i will give u good solution.
bro
svk
Old 04-11-2005, 11:41   #6 (permalink)
yasirmcp's Avatar
Member: 36825
Thanks Meter: 11
Originally Posted by New GSM
hi,
bro
svk
please post the solution to forum,then it will get the output to all in forum
please
Old 05-19-2005, 06:22   #7 (permalink)
Member: 104046
Red face
The same here! 2300 is dead. Local mode in Tornado only. The phone can be flashed, PM can be flashed. But the Test mode can't be initialised, so UI Settings can not be applied. And black lcd for some seconds if powered on.
So, I need a solution. Please, anybody!
Old 05-19-2005, 06:50   #8 (permalink)
Member: 137671
Thanks Meter: 8
my 2300 after flashing its ok but not signal, after writing pm phone can open without display,
anyone have this solution
Old 05-19-2005, 17:44   #9 (permalink)
Member: 106455
Thanks Meter: 3
use this way
- use erase file 2300 fill in mcu block and flash
- reflash phone again is normal ( mcu ,ppm)
- write 2300full.pm to phone
File Type: rar 1100-2300 eraseFlash.rar (320 Bytes, 280 views)
Old 05-19-2005, 21:29   #10 (permalink)
Member: 104046
I have all the flashes! I flashed the phone! I flashed the pm!
But I can't use UI Settings! The phone CAN NOT change the mode.
It is in Local mode only!
Old 05-20-2005, 17:32   #11 (permalink)
Member: 145590
der :
1- erase flash
2- write full flash mcu ;ppm
3- write pm 1100
4- If no restart phone again write flash mcu ;ppm
good louk and tel me what happen
Old 05-21-2005, 00:50   #12 (permalink)
Member: 104046
Thanx, but I have already tried to erase the flash, actually I tried everything with software. And now I'm absolutely sure that is hardware bug. But I dunno what kind of bug, what component has a bug. Had a similar problem with 3120 - it showed 'Local mode' while being powered via battery but worked with Tornado. It was necessary to remove on component near PA. The bug was solved.
So I think 2300 has smth alike. But what?!
Old 05-21-2005, 09:06   #13 (permalink)
Member: 106455
Thanks Meter: 3
Hi, I think your phone is not power on but is can flash compleate and It is this promblem you chang 32K crystal near UEM post again is happen
Old 05-22-2005, 15:30   #14 (permalink)
Member: 145639
salam to all some one tell me about to open 6600
Old 05-22-2005, 21:32   #15 (permalink)
Member: 104046
Thanx man. But it didn't help. Tried to resolder the crystall, tried to flash even without the crystall. But all the same - 'Local mode' with Tornado, and black flashes on lcd via battery.
2300 dead after flashing jetawo ademola Nokia Digital Core Technology 4 ( DCT-4 ) 10 05-09-2005 10:55
1100 & 2300 Dead After Bad Cable dannyogolo Twisterflasher 12 03-27-2005 10:21
2300 dead after flashing gbada Nokia Digital Core Technology 4 ( DCT-4 ) 8 03-07-2005 19:53
2300 Dead after erased pm FITOS Nokia Digital Core Technology 4 ( DCT-4 ) 3 03-02-2005 15:59
2300 dead supremegsm Nokia Digital Core Technology 4 ( DCT-4 ) 2 10-22-2004 20:42
Page generated in 0.38741 seconds with 9 queries
