03-22-2006, 05:59 | #2 (permalink) | |
Freak Poster Join Date: May 2005
Member: 143322 Status: Offline Thanks Meter: 35 | here it is.... Quote:
Br. Faisal. GSm Mobile Lab. | |
03-22-2006, 10:50 | #3 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: CHANDIGARH - INDIA Age: 59
Member: 2822 Status: Offline Thanks Meter: 152 | Quote:
Hi @jignesh_1000 and all other NewComers:- Pls follow the RULE to REPAIR your MobilePhone as:- 1. JUMPERS cannot be used for every fault, you can use jumper only 4 broken TRACKS on PCB due to Physical or Electrical Damage. 2.You can put JUMPER 4 AntSW also ONLY 4 TESTEING. Must replace with New AntSW after you have done your Test. Otherwise you will get LOW SIGNAL LAVEL or VARIABLE JUMPING SIGNAL. Another worse effect will be that you are giving about 2Watts of RF energy DIRECTLY into your Mobile Receiver Section which is Designed to work on very low level of RF energy, This way you are SURE to damage your Rf RECEIVER beyound repair. 3. JUPMERS can be used in case of ****N FUSE but THICKNESS of wire is Important. 4. You can also use JUMPERS 4 some BUFFER ICs which basically have Low value of Resistance between two points( Less than 2-10 ohms).ie SimCard Buffers. So pls learn ELECTRONICS first Before you START Mobile Repair , and You can take this post of mine as YOUR FIRST LESSON. PS : Pls now never ask how to bypass COBBA / HAGER / FLASH-RAM /and even CPU with JUMPERS wbr Ashwani Gaur www.gsm-magic.com +91-9815009105 | |
03-22-2006, 16:59 | #4 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | @ Ashwani Gaur ..!! Dont waste your time brother , " NaughtyCell " is my secound ID here on this forum , I used that name to figuer what I'm goeing to do after I'v got sick from thos persons whoum only looking to the mony inside the customer's pocket !! and no more service or care or any damme thing !!. So I have to be naughty , saucy , and shameless |
03-23-2006, 11:07 | #5 (permalink) | |
Hummm You maybe NaughtyCell or jignesh_1000 it makes no difference to me or anyone else who is trying to help make clear ur concept of mobile repair. Yes its a wastage of time to tell something important to a person like you. sorry for that I did it for you. I only talked something (rather everything) Technical here. So i dodnt understant what you talking here (@ I'v got sick from thos persons whoum only looking to the mony inside the customer's pocket !!). Anyway its upto you how you take anyones words. All the Best (for all the TUKKA reapir you will do in Future) If still looking for ALL JUMPER TECHNOLOGY in Mobile Repair you MUST visit this SITE (all 4 FREE , thanks to bungle_uk):- http://petit.philou.free.fr/ wbr Ashwani Gaur www.gsm-magic.com | |
03-24-2006, 21:45 | #6 (permalink) |
Member: 214350 Status: Offline Thanks Meter: 17 | What I ment is that they'r just looking to the mony so they need the fstaes and easiest way , look at the picture , make a stuppid jumper . then it works !! . will get paid , no logic , no service , even it will better if he comes again with other problem as long as he doesnt know that it is the cause of that brilliant Jumper!! |
03-24-2006, 21:54 | #7 (permalink) | |
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
but I'll wait untill you find your missed point ! | |
03-27-2006, 18:57 | #10 (permalink) |
Member: 2822 Status: Offline Thanks Meter: 152 | *********************************** but I'll wait untill you find your missed point ! *********************************** No offence No insult No raciest felling I found the missing point. You and jignesh1000 are not same. wbr Ashwani Gaur |
03-28-2006, 17:50 | #11 (permalink) | |
I was reading in hurry , that gives the missmatching , so it is better not to rush out thanx brother for your reply. BR | |
2300 ringer ic jumper | jack_ny90 | Nokia Hardware & Hardware Repair | 21 | 02-16-2011 18:26 |
Nokia 2300 only display lights | vipcomm | Nokia Hardware & Hardware Repair | 12 | 06-04-2009 09:29 |
3220 No display light . . .. Need Jumper solution. | amol_sm | Nokia Hardware & Hardware Repair | 4 | 08-21-2008 17:19 |
Nokia 2300 display lights not working | smkazim | Nokia Hardware & Hardware Repair | 1 | 05-30-2007 02:53 |
Problems in 2300 no display light | mobilemafia | Nokia Hardware & Hardware Repair | 15 | 07-01-2004 10:42 |
