2300 no light when select ringtones i got 4 nokia 2300 no light when i select ringtones.but when i off the rhythmic backligth alert it ok.... |
hi SOFTWARE PROBLAM YOU MUST BE USING NEW VERSION.... 6.640... USE OLDER ONE 5.62 IT WILL BE FINE....... IN CASE PROB PRESIST PLE MAIL ME AT [email protected] WBR MUNNA +919810626677 |
i try to downgrade the phone to 5.62, but the phone won't power up, if i flash back the same version, it works, BUT with BUGS. |
software problem. full erase, mcu + ppm v5.64 + pm and unlock if should be ok :) |
have you tested old flash this was working but with new flash chip even with phoenix phone dies :D after downgrade |
i already test on some old sets. I can flash 5.62 and 6.64 to the phone without having problem, only the new sets have the problem when we downgrade the version = it won't power up, if flash to the 6.64, the phone will have the light problem. |
nokia sw v6.62 had some problem..old 2300 can be downgrade..some of new 2300 can not be downgrade and it will couse flash ic defective..even u erase flash..it also can not...(replace flash ic) |
