Old 07-25-2006, 16:35   #1 (permalink)
Member: 93214
Thanks Meter: 18
2300 power on only in ufs..urgent
2300 power on only in ufs..i flashed with higher and lower versions same problem continues...any solution help me
Old 07-25-2006, 18:00   #2 (permalink)
jollen_9's Avatar
Member: 275677
Thanks Meter: 22
bro.hw problem... i think it's in the UEM...
Old 07-25-2006, 18:09   #3 (permalink)
Member: 79614
yes boss if you allready trym it flash on higher and lower version uem is the problem
Old 07-25-2006, 18:32   #4 (permalink)
Member: 249504
Thanks Meter: 2
did you clean onoff button maybe, little probability
Old 07-25-2006, 18:48   #5 (permalink)
Member: 94090
Thanks Meter: 26
it may be flash IC
Try heat flash or reball flash
Old 07-25-2006, 21:36   #6 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
Originally Posted by All_mobiles
it may be flash IC
What for? I wonder???
Old 07-25-2006, 22:19   #7 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
hi there
1st earse its flash n then reflash with 7.30 file version then tell me result
wbr
muhammad ahmad
Old 07-26-2006, 07:08   #8 (permalink)
Member: 93214
Thanks Meter: 18
Originally Posted by X-TRA
hi there
wbr
muhammad ahmad
i hav done but no result
Old 08-01-2006, 18:05   #9 (permalink)
Member: 79614
the last steps change uem ang yhe fladh ic and reprogram it wirte the new rpl thats the last steps if not its the boeard problem
Old 08-02-2006, 03:00   #10 (permalink)
Member: 96184
Thanks Meter: 6
i recon your all wrong, when you first flashed the phone it is likly that there was an error which would have changed the power levels, if you can get local mode, flash the phone but cannot power up the phone with a battery then the UEM would be behind it but its not faulty. you need to perform an energy managment calibration in 12volts using phonenix. the battery voltage goes way out in this fault, you need to use a good phone to copy the EM values to phoenix then connect the stuffed phone and load the new EM values to the phone. this works very well with 6255, 6111, 8800 and also 2300, 1100 have this problem. changing PA may help. if you are unable to perform this opperation- (takes 30 seconds) then you may need to replace the UEM as well.
Old 08-03-2006, 14:26   #11 (permalink)
Member: 101007
Thanks Meter: 27
some of tis prob i encounter i sovle it by changing the time crystal ic jus seat beside the uem grey in colr or brown in color wit some code ont it...
and s/w can be solve by the way erase flash then full flash.. write pm and init sim
use version not higher then 7.XX below is better
happy tryin
Old 08-03-2006, 17:02   #12 (permalink)
Member: 317428
Thanks Meter: 2
in hardware u chage r?? 4,7K BSI
6260 powers on only with UFS mr_loverman HWK 3 08-21-2008 19:30
6260 on only in ufs solution eldhoseca WD2 & APE (Symbian Phones) 0 07-21-2006 13:59
nokia 6260 on only in ufs .....help me ......plz eldhoseca Nokia Hardware & Hardware Repair 0 07-12-2006 11:38
6260 on only in ufs,...help me please..... eldhoseca WD2 & APE (Symbian Phones) 0 07-12-2006 11:31
help!!! 6101 power on only with ufs tiosif Nokia Hardware & Hardware Repair 1 03-10-2006 17:03
Page generated in 0.38936 seconds with 8 queries
