Old 05-01-2010, 10:12   #1 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
2310 1600 1110 alwase light on solve
after change light ic if same try this one
The Following 6 Users Say Thank You to GSMTURBO For This Useful Post:
Old 05-01-2010, 11:32   #2 (permalink)
Member: 1092450
Thanks Meter: 196
RapidShare: 1-CLICK Web hosting - Easy Filehosting
SET LIGHT ALWAYS ON SOULTION 100%%%%%%
Old 05-01-2010, 11:36   #3 (permalink)
genehack's Avatar
Member: 10468
Thanks Meter: 121
nice job.. thanks for sharing brother....
keep sharing bro...
Old 05-02-2010, 00:44   #4 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
its not relate to light, check right solution
Rashid Ahmed Nadeem
The Following 4 Users Say Thank You to r a nadeem For This Useful Post:
Old 05-02-2010, 06:50   #5 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
brother its not possible ........b coz it is not light related
part(just a filter on main power track)
read r a nadeem post only 3 way tracing in this kind of cases
1st light ic driver 2nd light ic 3rd power ic........ if ur set short b coz of water demage
then try to remove this filter.........
The Following User Says Thank You to imran zafar For This Useful Post:
Old 05-03-2010, 07:19   #6 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
bro i know u and nadeem r masters but i solve that then i post i know its power related but work for me
Old 05-03-2010, 07:26   #7 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
bro i solve brfore post it was little water damage light was alwase on i change light ic and tranzister but same after that i remove that part light became normel
Rashid Ahmed Nadeem
The Following User Says Thank You to GSMTURBO For This Useful Post:
Old 05-03-2010, 07:32   #8 (permalink)
mmmfaruk's Avatar
Member: 1114923
Thanks Meter: 224
change 3 lag component will be solve 100%
Old 05-03-2010, 07:45   #9 (permalink)
Member: 328187
Thanks Meter: 1,687
its ur luck.....
but i m sure ur set was water damage
when u wash the board foalt remain
if u want to confirm it resold that same
capacitor and check again......
Old 05-03-2010, 08:12   #10 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
bro ckeak 3 pin regulator @ line
then chenge ic
bro cheak @ post your result
The Following User Says Thank You to rakib_sheak For This Useful Post:
Old 05-03-2010, 08:27   #11 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
sir i already do that problem was that parts
its ur luck.....
Old 05-03-2010, 23:26   #12 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Dear
May your capacitor was faulty , But its only B+ filter , may its short due to water damage , but not effect as light keep on , if we consider its was short , then may its create sim fault , may light did not work ,sound noise fault or others faults ,but its did not light always on. either in open or short condition , if it did as you said then its was an accident , nothing more , test just only remove it and remain it unsold . nothing will happened
Rashid Ahmed Nadeem
Old 05-03-2010, 23:29   #13 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
One thing more read above some posts , what they said , or give me link any other saying same as you said
Rashid Ahmed Nadeem
Old 08-31-2010, 11:10   #14 (permalink)
shehryar mardan's Avatar
Member: 1033862
Sonork: 100.1652017
Thanks Meter: 538
dear
This file has been removed from the server, because the file has not been accessed in a long time.
plz upload in 4shared in once again
[email protected]
Old 09-10-2010, 07:20   #15 (permalink)
Member: 434631
Thanks Meter: 77
1600 2310 always light on
1st check software before going to hardware
mostly only ui setting help you in this case if
not you can go for hardware as given above
by our senior members.
regd:- Tony
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.24146 seconds with 11 queries
