Old 03-22-2009, 04:17   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
2310 Contact Service
Hello, I get 2310 in Contact service. i remove the resistance but after removing it shows Local Mode and also remove the resistances behind Battery Connector same. now phones shows Local Mode.
I try to flash it with J.A.F but gives error. here is the LOG of Flashing.
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-189\
Searching for default location of ini...
Checking path: \Products\RM-189\
Searching for JAF saved location of ini...
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\2310-6.52\rm189_06.520
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\2310-6.52\rm189_06.52ad
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\2310-6.52\rm1890_nai6.52ad
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\2310-6.52\rm189_06.520
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B28; Loader chk: cb
Loader is ready...
Error Auth!
any friend have any idea about this fault?
Thanx in Advance.
Old 03-22-2009, 09:47   #2 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br now you shot the resistance. from the removing place................try it..
The Following User Says Thank You to biniesh_08 For This Useful Post:
Old 03-22-2009, 10:35   #3 (permalink)
Member: 98575
please the send diagram of remove the resistance
Old 03-22-2009, 11:17   #4 (permalink)
biniesh_08's Avatar
Member: 843418
Thanks Meter: 740
br try it.............
Old 03-23-2009, 17:02   #5 (permalink)
Member: 432663
plz show the solution of charger not supported in nokia 2610
Old 03-23-2009, 17:07   #6 (permalink)
Member: 936437
Thanks Meter: 2
flash complete end unlock ..... ok test by me
1110i, 1112 , 2310 contact service abhishekh53 Nokia Digital Core Technology 4 ( DCT-4 ) 3 08-06-2010 10:35
2310 contact service mobilehut1 Nokia Hardware & Hardware Repair 12 12-12-2007 11:19
2310 contact service after downgrade !help ! crown Nokia Digital Core Technology 4 ( DCT-4 ) 19 11-27-2007 08:29
why not the solve 2310 contact service probem maheshsaiganesh MT-BOX 3 01-06-2007 09:14
Page generated in 0.16074 seconds with 9 queries
