Old 09-11-2008, 05:25   #1 (permalink)
Member: 857244
N95 Rear Casing Adhesive
also posted at hofo. need help asapppppp
hey, quick question. Well on the side where the 3.5mm headset jack is, the adhesive stickyness has worn off on the underside of that side. so i had to put paper in there so it wouldnt creak.
(under the paper, is where the adhesive tape wore off)
anyways, my question is, instead of buying a new rear casing could i just buy double sided adhesive tape and put it on? if i can, any advice on which one i should buy? this creaking is driving me nuts, and the paper makes the left side buldge out unevenly when i put it back on the phone.
(2) is how it should be, (3) is where i put the paper in, (1) is how the rear casing buldges out and makes the housing fit and look uneven. i need to know if i can do this adhesive tape job
Old 09-11-2008, 05:46   #2 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
hi
which paper you put at 3 , take out it....
not help you any adhesive tape, quick adhesive(instant adhesive) solution will help you but after that when you need to open it , you should broken it.....
but better way is that you must buy new casing.
b r
GSMish
Old 09-11-2008, 06:54   #3 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
buy new casing,,,lahhhhhhh
Old 09-11-2008, 13:06   #4 (permalink)
Member: 857244
i would but the housing is 50 dollars and my casing is still in pretty good condition, excluding the adhesive problem. Amit Tank, im having a bit of a problem understanding your post, so will adhesive tape work? I mean if i take out the paper and stick double sided adhesive tape where the old adhestive spots wore out, wouldnt it work?
Old 09-11-2008, 13:34   #5 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
no not use doubleside tape,only use instant adhesive only , which stick instantly ,
and it use innerside of cashing.
with one or two drop adhesive press it few mnts..
b r
GSMish
Old 09-11-2008, 15:45   #6 (permalink)
Member: 857244
could you use my picture to circle the places where i should? i dont want to ruin the phone by making a mistake. Quick question, if i use instant adhesive, wouldnt that ruin my housing? Like, would i still be able to take off the housing? Or if i try will it rip it up and ruin the phone?
Old 09-11-2008, 16:12   #7 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
onetime you stick with quick adhesive then you not use again , for open it you should breck it..
(adhesive drop at leftside(inner) where are open casing and press)
dear better is that you buy new casing....if you are expert for it you can do it easily,for onetime use...
b r
GSMish
Old 09-11-2008, 17:25   #8 (permalink)
Member: 857244
ok but if you had to recommend a tape, what would it be?
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] jus_chillin Cyclonebox 19 03-29-2010 11:57
how to open my N95 casing raymond72k4 Chinese Models & Cloned Phones 1 10-24-2008 13:25
Compatible Leather Case with Strap for Nokia N95 Phone IPMART ipmart WebShop 1 09-25-2008 22:18
Nokia N95 Exclusive original leather case in UK gsmuk Main Sales Section 0 07-09-2007 22:57
Page generated in 0.18294 seconds with 10 queries
