11-21-2009, 08:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | 2310 strange problem witch was dead when i handle it. and not detectable with flasher. i have changed it,s upp and uem now mobile is detecting with ufs and also erase and flash ok but not booting in local mode for extrect cnt file and also not booting in normal mode. please help me if anyone have the solution. Thanks in advance. |
11-21-2009, 08:38 | #4 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | here is the log 1st Boot Ok, DCT4, UPP: 2201 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u_intel.fia, Ver: 4.55.0 Algorithm Ok, MSID: 84065134C00EEB5F9BDAE8091F Decoded MSID: 3E4EBAE9-0019060E-A8000000 Encoded FAID: A256E8E1-F11C7B80-BF753900 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:37 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:16 Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:02 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
11-21-2009, 08:54 | #5 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0019060E:2984DA60 Programming Content Pack ... rm1890_nai6.52ia: [DCT4,DCT4 ALGORITHM] size: 187.07 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Area [01380000-013BFFFF] erased in 2.453 s Flash programming ... Programming completed in 1.671 s Content extract fail, continue anyway ... File Processed in 30.531 s Processing file: rm189_06.52ia ASIC ID: 0x2201 [UPP_2M ver: 2] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0136 B418 01A8 0980 4800 6124 8820 6414 u_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5538 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0019060E:2984DA60 Programming PPM ... rm189_06.52ia: [DCT4,DCT4 ALGORITHM] size: 1.26 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Area [011E0000-011EFFFF] erased in 0.593 s Area [011F0000-0137FFFF] erased in 14.922 s Flash programming ... Programming completed in 11.484 s File Processed in 48.953 s Flashing completed in 2 min 42.703 s Phone not responding ! Total time to process is 3 min 5.390 s |
11-23-2009, 06:19 | #8 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | now prblem found R=2153 was short its one side both points. i release it but now mobile is losing local mode & test mode after one second. just show one screen for one second. after that gone off.changed uem again but same now. Last edited by >>PakFones<<; 11-23-2009 at 06:25. |
11-23-2009, 06:27 | #9 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | BROTHER,WITH CABLE PHONE SHOW LOCAL MODE OR TEST MODE BUT NOT ENTER NORMAL MODE RIGHT? THIS CAUSE 2 RESONS MAINLY ONE IS BSI RESISTER OR SECOND IS SECOND LOACL CRYSTAL TRY TO CHECK THIS SOLUTION THEN POST RESULT |
11-23-2009, 06:59 | #10 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | sorry dear i don't understand local Cristal. one more thing witch i note when i turn on the mobile uem heating up mean something short.and mobile not stand power on more then 1 or 2 second. am i right? now need to cut off power of some parts like radio ringer ic etc. can any body help me. |
11-23-2009, 07:03 | #11 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | Quote:
11-23-2009, 07:25 | #12 (permalink) | |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Quote:
Dear as i said just for one second when i press power button and repeat it continually showing this Init Normal Mode Failed, no SIM Card MCU Sw: V 6.52 11-12-07 RM-189 (c) NMP PPM Sw: V 6.52 11-12-07 RM-189 (c) NMP IA Prd.Cd: 0541719 Bpr.Cd: 0531456 Pro.Sn: DMH540109 HW : 0501 PCI : UEM : 1328 UPP : 8705 RFIC : DSP : LCD : WIN:SYRS:01 ST7506 IMEI : 351941-03-392587-6 SLconf: B12-1B-747C506E638 SLprof: 0D0000000001000-0 SLvar : 00003519410339258700 SLaux : 00020000 Provider: Not Found #pw+ 822 511 246 057 521 +1# #pw+ 884 851 302 230 363 +2# #pw+ 354 446 372 266 653 +3# #pw+ 048 333 461 645 746 +4# #pw+ 248 345 265 605 253 +5# #pw+ 218 165 131 623 170 +6# #pw+ 844 821 265 250 236 +7# | |
11-23-2009, 09:28 | #13 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Problem solved by changing network ic. you can see in the picture.that was bad. and cause this show contact service & not stay on local or test mode. Thanks to all who reply me and help me in this thread. here is the unlock loge of this phone.and also selftest report. Imei net: 3519410******** Counter: 0/3, 0/10 CONFIG_DATA: B121B747C506E638 PROFILE_BITS: 362E35320A01312D SIMLOCK_DATA corrupted! Updating SIMLOCK ...Error 1 PhoneType:RM-189 SwVersion: V 6.52 11-12-07 RM-189 (c) NMP MCU file: rm189_06.520 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...Area [01140000-0115FFFF] erased in 0.766 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x2201 [UPP_2M ver: 2] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005732C8:2984DA60 Area [01140000-0115FFFF] erased in 0.781 s Programming ... Programming completed. Completed in 29.906 s Reading Simlock info ... Imei net: 351941********* Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
2310 strange problem | saqi160 | Nokia Hardware & Hardware Repair | 4 | 10-29-2009 09:03 |
2310 strange problem | saqi160 | Nokia Hardware & Hardware Repair | 2 | 10-28-2009 19:45 |
nokia 2310 strange problem,need help | bruk | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-19-2009 02:59 |
Nokia 2310 strange problem after flashin with UB | noagsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 09-05-2009 03:46 |
