01-15-2010, 07:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Chittagong, Bangladesh. Age: 39
Member: 734476 Status: Offline Sonork: 100.1604415 Thanks Meter: 2,485 | 1200 Failed! Aborting! Help need Detected PKEY: 90009699 Card life counter: 98.95% P-key nokia module version 01.02 Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.17.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.000 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.00aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai4.00aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.000 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 10011000 <=> Flash ID not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 846B846505627E940F274B9B8C MSID decoded: 3E4EBAE90017341FAA000000 FAID: A9303C7A4FBA4077D5BB3638 Operation took 0 minutes 11 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 31 seconds... Writing... Permanent Data Restore FAILED! Operation took 11 minutes 38 seconds... Restarting MCU... Failed! Aborting! |
01-15-2010, 07:48 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | 1ST U CHECK ITS USB POINTS...... if there's any shorting remove it. then heat uem normally.......... it'll solve ur problem 1000000%.. But if then also no luck just heat upp and try flash again........ U'll get it done..done.....done.!!!!!!!! |
01-15-2010, 10:01 | #7 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 45
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
RH-99_dp_v_37_00_MCUSW5_91 100% solved. | |
3110 flash failed aborting-help me | matnuacai | Nokia Base Band 5 ( BB-5 ) | 20 | 05-06-2011 12:25 |
1200 failed aborting help me | haigoshi | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 02-17-2009 08:21 |
