Old 05-21-2010, 18:22   #1 (permalink)
Member: 812164
Thanks Meter: 17
2330 shut down aftr 5 sec
hi frends i hve problem with 2330c shut down after few seconds ani solution i flashd with upversin n doin all possible things but no solution i think its uem prob ani one have solution of this problem
The Following User Says Thank You to mirza_alamgir For This Useful Post:
Old 05-21-2010, 18:33   #2 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
post log........................................
The Following User Says Thank You to abdurrahimsagar For This Useful Post:
Old 05-21-2010, 18:43   #3 (permalink)
binthabit's Avatar
Member: 187686
Sonork: GHANIM
Thanks Meter: 48
i have the same problem
Old 05-21-2010, 18:54   #4 (permalink)
Kenthus's Avatar
Member: 834709
Thanks Meter: 66
cek vio at c2410 drop to 0.7volt when handset shutdown!
this my solution I have tested. jumper with resistor 47 ohm from c2410 to c2411
goodluck
Old 05-21-2010, 19:12   #5 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
dear bro that is 100% hardware problem
Old 05-21-2010, 20:04   #6 (permalink)
Member: 1281680
Thanks Meter: 142
remove clock crystal and will be done tested on more than 10 phones
Regards
GsmFreaks
The Following User Says Thank You to GsmFreaks For This Useful Post:
Old 05-21-2010, 20:08   #7 (permalink)
Member: 347023
Thanks Meter: 345
bro can you upload clock crystal image
Old 05-21-2010, 20:18   #8 (permalink)
Member: 1281680
Thanks Meter: 142
i don't have 2330 schematic at home and also 12:16 am it is but i can guide you how its look like look the image . post the results also its helping to other solution work or not Thanks
Regards,
GsmFreaks
The Following 4 Users Say Thank You to GsmFreaks For This Useful Post:
Old 05-22-2010, 18:08   #9 (permalink)
Member: 812164
Thanks Meter: 17
thank to all of u tomorow i will try this
Old 05-24-2010, 07:02   #10 (permalink)
Member: 812164
Thanks Meter: 17
ya my shut down prob is solvd by removiing clok crystl but now fone some time error in connection and some time hang i also flash with 9.55 version
Old 05-24-2010, 07:16   #11 (permalink)
xannix_7575's Avatar
Member: 847117
Thanks Meter: 71
LOOK for a good crystal then put it...
then apply this jumper..
if still off after connecting that jumper
then flash your phone using the lowest version..(do not remove jumper)
100% solved my problem...
good luck
The Following 4 Users Say Thank You to xannix_7575 For This Useful Post:
Old 05-24-2010, 08:06   #12 (permalink)
Member: 1285461
Thanks Meter: 89
hi 2 all
bro use mx-key and repiar SD
then your problem solved
good luk
Old 05-24-2010, 09:17   #13 (permalink)
Crazy Poster
Member: 542100
Sonork: http://cranktime.com/
Thanks Meter: 10
great very good solution man i just did my 2680 after removing crystal clock ic its working properly
thnx
Old 05-24-2010, 09:25   #14 (permalink)
Crazy Poster
Member: 542100
Thanks Meter: 10
now my cell starts hanging after changing crystal clock ic with another cell phone n shut down after 5 sec do u got any jumper for my cell plz reply
Old 05-24-2010, 09:41   #15 (permalink)
Member: 847117
Thanks Meter: 71
put back the old crystal then apply jumper
if u want to flash the phone dont use latest version,
lowest vrsion work for me
unlocking nokia 5110 version5.12 5.20 tomi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 02-25-2011 10:16
How unlock new nokia5110 version 5.20 ? Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-21-2011 07:45
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
How unlock Nokia version 5.20 Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-17-1999 17:35
Page generated in 1.99869 seconds with 9 queries
