Old 07-12-2006, 20:18   #1 (permalink)
Member: 293371
Thanks Meter: 8
Red face nokia 6600 start problem
6600 set is on only white screen show and after few second its will be off
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640
Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640
Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640
Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640
Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.52.0
Algorithm Ok, MSID: 845A8AD2C8BCB7A69358FD9495
Decoded MSID: 3E4EBAF7-00C8B096-A9000000
Encoded FAID: 9906D3BF-28694DFF-78AFB4FB
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 5A 8A D2 C8 BC B7 A6 93 58 FD 94 95 D3 ...Z.......X....
00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... .....
00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 C6 !.... .....!....
00000030: 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA ...u...x...{....
Error Data2:
00000000: B3 72 72 C0 88 00 00 21 01 10 00 02 20 00 C0 88 .rr....!.... ...
00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!..
00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 C6 00 00 EA .. .....!.......
00000030: 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA D3 72 00 u...x...{.....r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Old 07-12-2006, 20:30   #2 (permalink)
Member: 113076
Thanks Meter: 11
reflash it with jaf after unlock and wite pm
Old 07-12-2006, 20:33   #3 (permalink)
Fludor's Avatar
Member: 3081
Thanks Meter: 8
If this doesn't work, try a full erase, flash it with latest sw version write a good pm and also a format user area.
Old 07-13-2006, 13:22   #4 (permalink)
Member deceased !!
aseemvizag's Avatar
Member: 226535
Thanks Meter: 7
Remove the tick mark in "enable bt flashing" and flash. works 100%
post reply
6600 starting problem when keypad is attached Vijendra Saini Nokia Hardware & Hardware Repair 0 12-13-2007 09:31
nokia 6600 start uP sege WD2 & APE (Symbian Phones) 2 07-05-2005 02:23
Nokia 6600 BIG PROBLEM BadHabbit WD2 & APE (Symbian Phones) 3 08-07-2004 13:58
Nokia 6600 having problems with ringtones !!!! sifasli Nokia Multimedia 0 07-03-2004 22:53
Nokia 6600 Tone Problem umairsaeed Nokia Multimedia 0 05-18-2004 01:57
Page generated in 0.17606 seconds with 11 queries
